PSW 505 or DSW 500?
Am looking at the 505 versus DSW 500. I live in Europe and the 505 is impossible to find here so DSW 500 is the next best thing. Also, whats the major difference between the DSW 400, 500 and 600, big price diff here in Europe. Current using the following setup, thoughts appreciated
Front RTi8
Center: Csi A6
Surround: Fxi A4
A/V Receiver: cambridge audio azur 540R
Post edited by upwan on
  • greg2350
    greg2350 Posts: 544
    edited April 2010
    I went from the 505 to the dsw 500 major improvement dsw just an overall better sub for music and HT.:)
    TV: Philips 42" LCD 1080p
    Front Speakers: Polk Audio RT800i
    Center Speaker: Polk Audio CS1
    Surround Speakers: Polk Audio R50's powered of Denon AVR
    Subwoofer: Polk Audio DSW pro500
    AVR: Denon 3801
    DVD Player: Denon DVM 745 upscale 1080p
    Sat: Directtv HD 10
    Front Speakers Amp: Rotel RB 890
    Center Speaker amp: Rotel 970 BX
  • upwan
    upwan Posts: 8
    edited April 2010
    great thanks any big diff between the 500 and 600? its a $140 difference in price here
    edited April 2010
    The 600 is one nice sub..from Polk. The answer is YES you'll hear a difference. Every 3db is a hearable difference. If I'm not mistaken the 500 will get you down to 30 hz and the 600 to 25hz you WILL hear that and probably also 'feel' it a bit more.
    cnh
  • anhchungdoan
    anhchungdoan Posts: 760
    edited April 2010
    Spec :The PSW 505 goes down to 23 hz while the DSW 200 is at 27hz but I do not feel the 505 actually goes down that low in a small 14 X16 room.
    Does anyone have an actual measurement ?
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited April 2010
    I would go with the 600 myself, as cnh said it will dig a little deeper and you will never wonder "what if" lol.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
    edited April 2010
    Good ear....
    Just check Polk's site:
    PSW505 28hz at -3db (the other figure is NOT realistic)
    DSWpro 500 30hz at -3db
    DSWpro 600 25 at -3db
    But more importantly check Polk's LOUDNESS (SPL specs) for all these...
    The Ultra (LOW) specs are 96db for the 500 and 100db for the 600...that is a hearable difference.
    The Top ratings are 114.3 for the 505, 118 for the 500, and 121db for the 600...all hearable.
    Now of course those measurements are under ideal conditions and you may want to 'meter' all this yourself?
    cnh
  • upwan
    upwan Posts: 8
    edited April 2010
    thanks for all the tips
  • madnod
    madnod Posts: 79
    edited April 2010
    i have the DSW PRO 600, and it's a great sub, u can hear and FEEL the bass, it shakes my 3 seaters in heavy bass scenes, i believe it might be going lower than 25 HZ.
    my room is 5.5m X8.5m and my setup is RTI As
  • rooftop59
    rooftop59 Posts: 8,120
    edited April 2010
    I have not heard either, but here is a good review of the PSW505 from a well-respected SVS employee:
    http://www.hometheaterhifi.com/volume_12_2/polk-psw-505-subwoofer-4-2005.html
    Mullen states that "Without much effort, I achieved an in-room FR of 23 Hz - 100 Hz" (of course this was with a parametric eq) which is pretty stout for the Newegg.com price, but I don't what the prices are like in Europe.
    Good luck!
    Paul
    Game Room 5.1.4:
    Bedroom 2.1
  • Satch0922
    Satch0922 Posts: 8
    edited May 2010
