Thread for the passive XO gurus (RTi A7)
gp4jesus
gp4jesus Posts: 1,969
edited August 2011 in DIY, Mods & Tweaks
This goes out to those who know more than I do. Another thread for passive XO gurus and RTi A7 owner/modifiers.
Bottom line: I don't see a series cap much less a shunt inductor on the Mid to provide the HP filtering suggested on Polk's site. 12dB/octave HP&LP for all drivers.
Read what I saw upon inspection of XO; I hope it makes sense:
Tweeter: 2 caps* paralleled**, shunt inductor, 2 caps* paralleled** - 18 dB/oct, right?!!
* in series w/tweeter
** w/each other; under 20 micro farads total
Mid: series inductor, shunt cap & resistor - 12 dB/octave LP, right?
NO SERIES CAP or SHUNT INDUCTOR on the mid
Sub: BIG series inductor, shunt cap 12 dB/octave LP, right?
This also suggests 4 ohms below 125hz. If I did the math right, 125hz HP series cap should be about 2500 microfarads.
Polk Tech spt stands behind the web site specs. How can Polk claim any Mid HP filtering w/out a series cap?
Unless they know something I don't, the site's not accurate.
anyone's comment please?!!
thnx for bearing w/me; tony
Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
Post edited by gp4jesus on
  • ShinAce
    ShinAce Posts: 1,194
    edited April 2010
    I'm gonna copout and say 'not enough info'.
    I could read through your description and layout the crossover, but everything you got there adds up. Tweeter, as described, is 18dB HP, mid is 12dB LP and woofer is 12dB LP.
    There are other factors to consider. If the inductance of the woofer is enough, we can use its natural high eng roll to crossover to the mid. So it may not need a HP(or in this case, bandpass). Other factors may apply to the mids. If they lose sensitivity in the very low end, playing them may not affect the oversall response of the speaker by more than, say, 0.5dB.
    Keep up the good fight!
  • FTGV
    FTGV Posts: 3,649
    edited April 2010
    OK gp I'm not a guru but I'll through my $.02 in.
    gp4jesus wrote: »
    Correct it is 18 db electrically,but the actual acoustic slope could be closer to 24 db(or greater) when the natural low frequency roll off of the tweeter is factored in.
    Correct ,but again the acoustical slope maybe be steeper.
    Yes.
    You have one too many zeros.For your 4 ohm assumption text book value the shunt cap would be closer to 250uf not 2500uf.
    If? there is no HP filter present on the mid then its low frequency roll off will be determined by the woofer/box tuning just like a normal woofer and will operate in parallel with the bass drivers.Does the mid have it's own separate enclosure?I,m not familiar with this speaker but from the pic I seen online it appears the mid may have it's own port thus it's own enclosure?
  • Face
    Face Posts: 14,340
    edited April 2010
    ShinAce and Fred already did an excellent job answering your questions. Let me just add a little more.
    Acoustic and electrical filters aren't the same thing. You can have a 2nd order electrical filter(1 cap, 1 coil), with 6 order acoustic rolloff. Not as common, but it can also go the other way, 2nd order acoustic roll off with a third order electrical filter, etc...
    As for Polk's 2nd order HP on their midrange with no parts in series with the driver, here's an example of another midrange that has a similar response: http://www.madisound.com/catalog/product_info.php?cPath=45_234_266&products_id=1315
    And as Fred mentioned, the cabinet tuning can also have a big influence on a mid's high pass.
    FYI, textbook/website crossover calculators are wrong 90% of the time.
    gp4jesus wrote: »
    :D
  • FTGV
    FTGV Posts: 3,649
    edited April 2010
    Face wrote: »
    :D
    Yeah its a rare instance when a "text book" design gives the desired response.
  • gp4jesus
    edited April 2010
    thanks everyone. I neglected to mention I'm looking only @ the electrical (filters). Your responses became reminders: the mid's inductance, cabinet tuning specifics, the different driver's natural rolloffs.
    I ran some tests Wed pm. Heard some things things that told me the subs & (6.5") mid may share the same enclosure space. Let me make one point clear: I do not see any HP filtering on the mid*. It wouldn't suprize me if Polk took the RTi A3 drivers & XO, put it in a bigger cabinet, added a 2nd order LP & 2 musical sounding (4 ohm in series) 7" drivers, and called it the A7. I don't consider that a bad thing.
    * I don't like that
    to FTGV & Shinace: Thanks professors! Looks like I aced the exam! I needed to be sure I recognized the different filter designs, interaction w/the driver aside. Also I remembered incorrectly the formula to calculate the value for a HP filter (@ 125hz)
    Early on I planned to use an EXO to bi-amp these even b4 I started this thread. In a msg I sent to Face I mentioned using tri-amping to determine the source of a brightness/edginess issue. Since then I realized I may run into a phase issue with the mid/tweeter filtering (12dB LP/18dB HP passive) and 24dB HP/LP active @ 125hz. I plan to continue the research to include cap upgrades* following the "cap shootout" results.
    * if I can get them into the cabinet!
    When I'm fininshed messing around I will have tri-amped rewired* A7s w/out passive filtering. Check out my system. I didn't list everything...
    * the stock wire is lame, particularly the mid, & especially the subs
    thnx again, stay tuned
  • Face
    Face Posts: 14,340
    edited April 2010
    What's wrong with no high pass filtering on the mid? The less components in the chain, the better.
    As for fitting upgraded components in the cabinet, it can be a chore. Make your own board to mount to the bottom of the cabinet, and run wires to it directly from the binding post cup, bypassing the OEM crossover board.
  • FTGV
    FTGV Posts: 3,649
    edited April 2010
    gp4jesus wrote: »
    ...the subs & (6.5") mid may share the same enclosure space.
    That would be an unusual approach as most designers of 3 ways prefer the midrange be completely isolated from the high pressure backwave of the woofers.
    It wouldn't surprise me if Polk took the RTi A3 drivers & XO, put it in a bigger cabinet, added a 2nd order LP & 2 musical sounding (4 ohm in series) 7" drivers, and called it the A7.
    From your description of the 7 that may not be far off the mark.
    I'm a big advocate of active crossovers and think atleast for experimental purposes you certainly could try an active unit between the mid and woofers.However for optimum results you would need to remove the passive LP section on woofers and since there is no HP section on the mid you won't need to remove it .
    A 24 db LR type should work well and I would try to set the xover point in the 2-300hz range.The addition of the steep 4th order roll off at the bottom of the midranges response should reduce distortion in the important midband as the excursion demands on the mid driver will be substantially reduced.
    There should be no phase issues if 1)a 24 db active network is used 2)the passive LP section on the woofers is removed and 3)crossing over in the 2-300hz range.
    Keep in mind if amplifiers with different gains are used for the woofer and mid/tweeter sections then the systems frequency balance will be altered.Most active crossovers will have a means to adjust the high pass and or low pass sections so you can restore the proper balance.
  • gp4jesus
    edited April 2010
    Face wrote: »
    I agree w/ the "less components" discussion. In this case at very high levels the mid* gets pushed* too hard while the subs loaf. HP @ 100hz+ would help a lot.
    * popped a couple of times
    If I read this right, run from the amp to "new" XO, then to BPs? Great tip! Easy "fix" for sure. That's what makes this forum great. Now I have to make up my mind exactly where to place the speakers & use the spikes for more clearence. Part of my interest in cap upgrade is curiosity for myself and other A7 owners. Read on for the "end product."
    Since my last post I pulled the mid & upper sub to learn the above (disappointingly) is true. Otherwise the cabinet seems well braced/built. Now if I could install a divider, creating 2 chambers... It so happens Polk braced the cabinet just below the mid port. Of course the trick is getting in there and attaching it. W/6 kids now, Natale Grace born Apr 22d, MY spare time is a very sparse, precious comodity. I'll resign myself to the easy, quick stuff* early on, like rewiring the cabinet, bypassing the XO, bi/tri-amp experiment, getting to the more complex stuff later.
    * have the wire, 10 ga, 12ga OFC, 18 ga OFC etc
    I'm a big advocate of active crossovers and think at least for experimental purposes you certainly could try an active unit between the mid and woofers.
    Been huge on active XOs since the early '80s. The Audiocontrol Richterscale 3 has a control to turn up or down the sub. The other has filter input gain plus separate adjustments for both HP & LP. Got more equipment than listed.
    Some went down for a nap; I'll do what I quietly can...
    thnx; stay tuned, tony
  • FTGV
    FTGV Posts: 3,649
    edited April 2010
    gp4jesus wrote: »
    IMO assuming the use of a good active crossover ,the performance gains made by the reduction in midband distortion and superior damping in the bass should/may? overshadow any downside of the added complexity in the signal path.
    Alternatively installing some acoustic foam or fibreglass between the woofers and mid should provide a measure of isolation between them.
    W/6 kids now
    :eek:Keep up the good work and you will soon catch the Duggars:D
    Congrats on the new arrival.
    Likewise,I have been running a fully active setup for about 4 yrs.
  • gp4jesus
    edited April 2010
    FTGV: spent half the evening last night editing a reply to the previous one.
    You're VERY right about active XOs
    the A7s need the divider. Polk put a bunch stuffing in the speaker. Unfortunatly it didn't work. When I listen to just the subs, I can hear their bass thru the mid. My curiousity over that prompted me to pull the upper sub & mid.
    Wednesday pm I may get to some rewiring, bypassing the XO, and bi-amping the mid/tweet. I, along w/some other A7 owners, want to know if the edgy brightness is the XO or the drivers. My $ is on the XO.
    anyway I agree w/your points. would love to see the details of your system.
    stay tuned, cheers tony
  • gp4jesus
    edited April 2010
    Upgraded to AR 12ga OFC over the weekend; have 100+ hours on them. Listened to the same Donald Fagen/Steely Dan tracks the first time I cranked them up the day after they arrived about 5 weeks ago. They are noticably softer w/reduced brightness at the same (loud!) volume levels.
    Couldn't make time to do full blown mid/tweet bi-amp tonight. Did make time to do the following:
    Ran thru a lively Steely Dan track 4 times. (Kid Charlemenge)
    1. Right side w/the mid alone, full range; left side as Polk built it with a pillow over the tweeter: little difference; right side fractionally softer
    2. right side-4 order active LP @ 2.2K*; left-same. Big difference; way cleaner
    3. Right side @ 2.8K*; left: as above. As clean, w/ more top end (of course)
    4. Right side @ 3.5K*; left: as above. As clean, still more top (of course)
    * Polk's site has them @ 2.7K 12dB, HP & LP...
    Will try full blown bi-amp w/both channel to confirm above results.
    Otherwise my conclusion: Either upgrade caps or bi-amp the mid/tweeter.
    Stay tuned. Cheers tony
  • FTGV
    FTGV Posts: 3,649
    edited April 2010
    gp4jesus wrote: »
    By the description above it appears you were cascading the active xover with the passive or did you remove the passive?The results of using them both on top of each other will be highly unpredictable and chances are good that serious response errors will occur.
    At the very least you will need the ability to make accurate measurements to see what is really happening. Crossing over in the 2-3k range is a lot more difficult than crossing over in the 2-300hz because of the drivers natural roll off's and break up modes etc are usually within an octave of the intended xover point.These will all have an affect the final response.
    However as I mentioned in a previous post I would stick to using your active in the 2-300hz range( along with the removal of the passive crossover from the woofers) as this should work well.In this lower frequency range the unfiltered response of the woofers and mid should have atleast an octave of overlap aswell there shouldn't be any cone breakup modes or large peaks or dips in the drivers response.Thus the response with the active should be close to predidiction.
  • gp4jesus
    edited April 2010
    Thanks for your interest and help! Sorry for coming across vague
    To clarify: I connected the amp DIRECTLY to the mid driver alone for all tests. It was quick and simple. Pulled the driver. Disconnected the XO. Ran speaker wire through the port below the mid. reinstalled the driver. First test was full range w/zero filtering.
    My goal: to get a feel for the reason for the edgy brightness. Is it the XO or drivers? Seems like the XO; posibly the XO overlaps the drivers.
    This weekend I hope to try the tweeter by itself with active HP* starting about 5K, going down to about 2K.
    * 4th order
    Again, thnx for your help. stay tuned tony
  • gp4jesus
    edited May 2010
    They're softer, less fatiguing these days.
    RTA* testing several weeks ago showed a broad 3-5dB* peak around 10K. Life has kept me from posting results.
    * low res display
    Still commited to bi/triamping as final, no-cost* solution. May pursue passive mid/tweet XO cap upgrade**-$ & which brand to buy, stumbling block
    * for me anyway
    ** purely out of curiousity
  • zingo
    zingo Posts: 11,258
    edited May 2010
    I also have been considering an active crossover, but the problem is tube XOs aren't cheap...
  • gp4jesus
    edited July 2010
    A quick RTA test update from several weeks ago:
    found RTA screen resolution setting & took careful readings at different volume levels. all dB readings relative from first measurement
    1. Peak centered @ 3550-4K hz confirming what my ears have told me all along.
    2. -5 dB @ 10 K then plateaing to above 20K
    3. greater than 10dB* dip centered below 2K* gently rising to -5dB plateau @ 500hz
    * posible XO interference
    Feel free to direct questions, comments, or flamouts to me
    tony
  • Face
    Face Posts: 14,340
    edited July 2010
    How close was the mic when you measured?
  • FTGV
    FTGV Posts: 3,649
    edited July 2010
    On what axis did you take the measurements?Response can change markedly with small changes in mic position.
  • gp4jesus
    edited July 2010
    distance: about 1 meter, on-axis
  • Face
    Face Posts: 14,340
    edited July 2010
    Was the mic tweeter level?
  • gp4jesus
    edited July 2010
    Face wrote: »
    Yes. Got similar measurements between T & M too.
  • gp4jesus
    edited May 2011
    upgraded the wire between the mid/tweet BPs & their filtering to AR 12ga OFC
    upgraded the wire between the mid & its filter to 14 ga OFC
    removed the sub LP filtering
    upgraded the sub wire to 8 ga, this channel's subs connected to its own XL280 w/10 ga MC
    Currently evaluating with music. Modded channel's bass noticebly more percussive
    will use RTA this weekend for comparative readings & tune sub/mid balance
  • gp4jesus
    edited May 2011
    latest configuraton:
    Adjustable Mid HP output & frequency on both channels. XO'd about 150hz
    Adjustable sub output & frequency for the channel w/upgraded wire.
    My ear tells me the range just above the mid HP needs a little help.
    hope to get time to take RTA measurements later today.
    cheers tony
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited May 2011
    Tony - Great stuff, but how about choosing one thread, instead of dumping the same info into three threads every time? :confused: I realize they are all related, but...
    Toolfan66 Posts: 16,908
    edited July 2011
    Can someone explan to me what an active crossover is?? what it does as opossed to a what I would call just a crossover??
    Thanks!!
  • gp4jesus
    edited August 2011
    Active XOs are between a pre-amp & 2 or more power amps; they handle filtering the different frequency ranges to designated amps.
    For example some might use a tube amp for mids & highs; to a tube amp; transistor amp for lows.
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2011
    Thanks!!
    gp4jesus has it right. But they can also be tailored better or tuned better to the speakers, preamp and amplifier that is being used.
    I have used electronic crossovers in PA work and honestly they are amazing in how much you can tweak the sound to fit the venue or room the system is in.
  • gp4jesus
    edited August 2011
    Joe08867 wrote: »
    ...they can also be tailored better or tuned better to the speakers, preamp and amplifier that is being used.
    great point Joe! You reminded me to mention: the better ones allow you to adjust XO frequencies &/or outputs to the different frequency ranges - very helpful if you have a "hot" tweeter or need to fatten the low end for a dance mix.
    cheers tony
  • Goga019
    Goga019 Posts: 13
    edited June 2016
    all, good day! I beg tearfully help novice. I recently bought the RTI A7 were in use. It seems they did upgrade the local master - I mean what is the change in the crossover. Help with a picture of the original crossovers RTI A7 or circuits that I can fix it as it should be. And as I will be very grateful to the people who will be able to explain to me a bit of how good or bad my look crossovers. With master who touched them no opportunity to speak. I really like my speakers and I do not want to change them, but I'm a little disappointed in the fact that the master had done to them. P.s. I live in Kazakhstan. All many thanks for your attention.
    Post edited by Goga019 on
    Don't drink and drive - just smoke and fly )
    Pioneer VSX 922-K + Polk Audio RTi A7 (by wrong bi-amping)
    Flac and SACD by HDMI
  • Goga019
    Goga019 Posts: 13
    someone, please, show to me photos crossover in the original from RTI A7.
