speakers
Im concerned whether or not my yamaha rx-v650 reciever has enough power to do justice to my monitor 70 speakers for home theater.any body have similar set up? reciever rated at 95 watts@7 channel.
Post edited by bproe on
Your AVR HAS pre-outs so start searching for an external AMP and you will be set.
DavidPolk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
I have the yamaha 565 with monitor 70s and think it sounds just fine. I am using all 7 channels and can't complain the least bit.
You CAN get by with the Yamaha and it'll sound OK but get a power amp for those front channels and it'll sound EVEN BETTER!
If you just got those Monitors....break them in SLOWLY...at moderate volumes for a while or you might fry the tweeter by clipping the Yamaha?
Once the break in they're a bit more 'resistant' to damage!
