speakers
bproe
bproe Posts: 3
edited April 2010 in Speakers
Im concerned whether or not my yamaha rx-v650 reciever has enough power to do justice to my monitor 70 speakers for home theater.any body have similar set up? reciever rated at 95 watts@7 channel.
Post edited by bproe on
  • Knucklehead
    Knucklehead Posts: 3,602
    edited April 2010
    Your AVR HAS pre-outs so start searching for an external AMP and you will be set.
    David
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • grimmace19
    grimmace19 Posts: 1,429
    edited April 2010
    I have the yamaha 565 with monitor 70s and think it sounds just fine. I am using all 7 channels and can't complain the least bit.
    edited April 2010
    You CAN get by with the Yamaha and it'll sound OK but get a power amp for those front channels and it'll sound EVEN BETTER!
    If you just got those Monitors....break them in SLOWLY...at moderate volumes for a while or you might fry the tweeter by clipping the Yamaha?
    Once the break in they're a bit more 'resistant' to damage!
    cnh
