Bridged Amp Question
Systems
I have a pheonix gold Ti 600.2 and 2 MM10's how do i am a little confused on how to bridge my subs to my amp. I would appreciate any help.
Thanks,
Kevin
Thanks,
Kevin
Testing
Testing
Testing
Testing
Testing
you have 2 pieces of speaker wire
take the positive from both wires and twist the ends together
stick that in the positive terminals on your amp
(its a 2 channel amp...has 4 sets of terminals...2 positive...2 negative)
now take your negative ends and twist them together
stick them in the negative terminal in the OTHER channel
then connect the positive with positive and negative with negative on your subs
on some amps, you have to flip a switch before itll let you bridge it...check your manual
btw...youre underpowering those subs
-Cody -
... and to boot you'll be running the amp at 2 ohms bridged, which it is not stable at -- so sizzle sizzles goes mr. amp.The Artist formerly known as PoweredByDodge
