Bridged Amp Question
Systems
Systems Posts: 14,872
edited November 2003 in Car Subwoofer Talk
I have a pheonix gold Ti 600.2 and 2 MM10's how do i am a little confused on how to bridge my subs to my amp. I would appreciate any help.
Thanks,
Kevin
Testing
Testing
Testing
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    you have 2 pieces of speaker wire
    take the positive from both wires and twist the ends together
    stick that in the positive terminals on your amp
    (its a 2 channel amp...has 4 sets of terminals...2 positive...2 negative)
    now take your negative ends and twist them together
    stick them in the negative terminal in the OTHER channel
    then connect the positive with positive and negative with negative on your subs
    on some amps, you have to flip a switch before itll let you bridge it...check your manual
    btw...youre underpowering those subs
    -Cody
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    ... and to boot you'll be running the amp at 2 ohms bridged, which it is not stable at -- so sizzle sizzles goes mr. amp.
    The Artist formerly known as PoweredByDodge
