Possible amp upgrade
kevhed72
kevhed72 Posts: 5,160
edited April 2010 in 2 Channel Audio
I am currently running my RTiA9s off an Adcom 545ii, which overall does a nice job...but, I have always been planning to upgrade to something with more power (at least 200wpc).
But, my rig does double duty, and a Parasound Halo A52 has caught my eye (yes, the A51 would be great, but not going to happen $).
Question, would I been disappointed with this amp rated at 125wpc for 2-channel....I know Disney Joe and a couple others have had experience with these amps...
Post edited by kevhed72 on
  • chargerman426
    chargerman426 Posts: 419
    edited April 2010
    I have neer heard Parasound gear but they look like they are built like a tank and I have good things about them. If I were you and $ is tight I would get some carver gear. If you wait you can pick up some amps for a dollar a watt (i.e. a 350x2 amp for $350). Thats how I stated my step into separates at 16.
    If life had more tubes it would be a lot smoother.
  • virtualdean
    virtualdean Posts: 286
    edited April 2010
    The last few tfm 42's went in the 450 range. 375 x 2 aught to do you.
    its a good thing i'm not actively pursuing one because the prices would be 200 bucks higher.:D
