Which banana plugs?
pploeser
pploeser Posts: 88
Can anyone recommend some inexpensive banana plugs that provide good clamping? I found some so-called Nakamichi plugs on ebay that work well thanks to the two set screws used to hold the bare wire in place. They come with a screw-on outer sleeve that comes loose too easily though. They were about $1 each shipped, so they're a nice plug for the money IMO. I like the Audioquest bananas with the two allen screws, but those go for more like $5-$10 each. I'd rather not spend that much. I've tried the cheaper parts-express bananas but they only have one set screw, and are pretty shallow. I'd like to have the option of using 10-16 awg wire with them. Any suggestions?
Post edited by pploeser on
  • pploeser
    pploeser Posts: 88
    edited April 2010
    I would honestly be ok with good solder type plugs too, if anyone can recommend some of those. Ideally they would have some way of indicating polarity (colored sleeve, etc.) but I suppose I could do that with heat shrink tubing as well.
  • krauley
    krauley Posts: 81
    edited April 2010
    Onkyo 808
    Emotiva XPA-5
    Polk Audio M70s fronts
    Polk Audio Cs1 center
    Polk Audio 50s surrounds
    Polk Audio 30s backs
    Polk Audio Psw505 sub
    Polk Audio Psw10 sub
    Oppo BDP-93
    PS3 slim 250gb
    Vizio 55" Led-lcd
    HTPC Evga P55/Intel i7-860/Evga 260 Sli
  • ALL212
    ALL212 Posts: 1,645
    edited April 2010
    I've used ViaBlue 'nanners. Put a copper sleeve over the bare wire - crimp the heck out of it - put the nanner over the copper and two set screws will keep it there.
    http://www.av-outlet.com/en-us/dept_379.html
    Aaron
    Enabler Extraordinaire
  • zingo
    zingo Posts: 11,258
    edited April 2010
  • NotaSuv
    NotaSuv Posts: 3,871
    edited April 2010
    Furtech F 202 lockin nanners, these are on a set of speaker cables I'm now using and work great..
  • Face
    Face Posts: 14,340
    edited April 2010
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited April 2010
    I bought some of these a week or so ago, and man do they make life easy, lol. Got them at the BX on base and paid way too much for them, but it was an impulse buy, lol. Could have gotten 16 of them at monoprice for less than what I paid for 8 of them here, lol.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • pploeser
    pploeser Posts: 88
    edited April 2010
    Thanks for the tips (pardon the pun :))
    Anyone know what range of cable diamaters the GLS plugs work with? It looks like they clamp down on the OD of the insulation where it enters the plug. I could see that not working well with a wire that was too small. I'd hate to count on one set screw to hold it all in there.
    I've considered the viablue and furutech connectors before. They appear to be well designed and constructed - and look great too. I'm just not sure I want to spend that much just yet.
    The monoprice and solder-type plugs are definitely high on my list of options.
  • Face
    Face Posts: 14,340
    edited April 2010
    Skip the monoprice nanners, IMO they degrade sound quality.
  • mantis
    mantis Posts: 17,316
    edited April 2010
    I like Niles because you can reuse them over and over. As much as I switch out wires and custom make my own , these are fantastic. Yeah you pay slighty more but you get so much more.
    No need to shop around buy these and be happy
    http://www.smarthome.com/6744GB/Niles-GC-BPR-Gold-Plated-Single-Banana-Plug-Wire-Connectors-Pair/p.aspx
    Dan
  • fbm211
    fbm211 Posts: 1,488
    edited April 2010
    Get pure copper or silver.Pay a little extra for quality.Bronze,nickle,brass,etc=Bad
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • zingo
    zingo Posts: 11,258
    edited April 2010
    pploeser wrote: »
    I've used them with 12g wire, and I think the screw goes almost all the way to the other side of the barrel, but if you wire is still too small, you could always just strip a little extra back and double it up (but then your speaker wire might be too small anyway). I like the GLS plugs because they not only clamp on the conductor, but the bottom part of the barrel claps on the jacket when you tighten them down.
  • polkatese
    polkatese Posts: 6,767
    edited April 2010
    I use GLS nanners like Zingo has. On a couple sets of them, for some reasons or another, the leaf springs became flatten out, thus, came lose from the power-amp socket, causing a short that luckily I immediately noticed and turned off the amp before it caused any damage. Still, a reason to be PO for me. Luckily I had enough of these, and I replaced them with new sets.
    I wonder though, how those leaf spring could flatten over time since I hardly touched them. The best nanners for me is the sawtooth kind. Those hold very tightly, no risk of these looseing up.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • pploeser
    pploeser Posts: 88
    edited April 2010
    zingo wrote: »
    ...not only clamp on the conductor, but the bottom part of the barrel claps on the jacket when you tighten them down.
    This is more specifically what I was wondering about. If the jacket on the cable is too small, the set screw on the bare wire will be the only thing holding the cable and plug together. Just curious if anyone knows the smallest id of the clamping area.
    Nice looking cables. I just made a set of bi-wire cables using Canare 4S11 and the same pants shown in your photo. Just curious, what wire do you use?
  • Krazyz1
    Krazyz1 Posts: 256
    edited April 2010
    Check out Parts Express. 24kt. plated. 1 piece pressure screw. Stack-able , and will hold 10ga. wire. Very satisfied.
  • jinjuku
    jinjuku Posts: 1,523
    edited April 2010
    krauley wrote: »
    I have some of those and have one complaint. The actual male leaf plug also screws in. It is not a solid piece with the top half of the plug. I could see that causing some issues. My solution was to simply crank up the soldering iron and run a bead around where it screws in.
    Just an FYI for those who may not know.
    I have been use the locking banana's from GLS. Fortunately I picked up my stash before the ~30% price hike. I do like them.
