Anyone build a custom entertainment center?
kevhed72
kevhed72 Posts: 5,144
edited April 2010 in The Clubhouse
My next big investment wil be a 58" plasma, but I want to start working on a suitable entertainment center. MANY of the store bought one just don't cut it in terms on center-speaker ( I have CSiA6) placement and number of shelves for components. Here are some specs. I want to build in my own:
a. 3 "rows" of shelves, not including the top which holds the plasma screen
b. 3 "columns" of shelves - in all, 9 spaces to hold components, including center channel (CSiA6)
c. Height on entire unit would be approx. 28", give or take an inch. (This height would give center channel good distance off floor, since ideally you want all the front tweeters around the same height)
d. Width of entire unit would be around 50" or so
e. Entire unit would be made of wood, unless I can find pre-cut shelves made of something else, ie glass, MDF, etc
f. Entire budget is approx. 300.00 for project.
g. The unit cannot look like something out of Sanford & Son, so what type of saw may I need to invest in ( ie. table saw??)
Any ideas / advise is appreciated, and any PICTURES you can post of what you all built would be great...I know we have some pretty handy people on the forum...
Post edited by kevhed72 on
  • acmf74
    acmf74 Posts: 937
    edited April 2010
    great post! I was about to post the same question :)
    BTW I decided on the below TV with the help of fellow Polkies.
    http://reviews.cnet.com/flat-panel-tvs/panasonic-viera-tc-p58v10/4505-6482_7-33490591.html
  • kevhed72
    edited April 2010
    you must be a psychic...thats the model.
    I have thought about the 65" version, but I would be cutting my seating distance pretty close though...
  • Conradicles
    Conradicles Posts: 6,343
    edited April 2010
    If I did build one, it would have a HUGE spot for a center channel speaker.
  • Systems
    Systems Posts: 14,873
    edited April 2010
    I had built a custom center years ago(1990) and one thing I did when I got my Plasma is I just mounted it on the wall above the center and then I had room to just put the center speaker on the top of the unit.
    I highly recommend if possible to mount your TV on the wall and as high as possible and still view it comfortably. Also helps to have a "false room" behind the center to manage your wires.
    I built the center out of Oak plywood and put in adjustable shelves(another highly recommended for future changes in your components...)
    Testing
    Testing
    Testing
  • Amherst
    Amherst Posts: 695
    edited April 2010
    I am in the planning stages of a custom built center. My display is wall mounted with separate speakers, the speakers are currently attached to the side of my current cabinet.
    The plan for now is to incorporate home built speakers for the monitor into the cabinet. I have access to some nice woodworking equipment to build the project. The key is going to be being able to get the speakers to sound decent.
    Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
    Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
    Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU.
  • acmf74
    acmf74 Posts: 937
    edited April 2010
  • Systems
    edited April 2010
    acmf74 wrote: »
    http://www.standoutdesigns.com/?gclid=COP_1JqWhKECFSd75QodulKNww
    Perfect but a little more than I want to pony up for.
    Yeah thats a nice one, very buildable though....
    Testing
    Testing
    Testing
  • jinjuku
    jinjuku Posts: 1,523
    edited April 2010
    You could google for RTA (ready to assemble) cabinets. I used two and then just put shelving in between. Turned the cabinets upside down and cir sawed the toe kicks off.
    Just matched up some paint and that was it.
    Used a 3/4 ply on top with molding for the edge treatments. Amps/X-Over/HTPC are in the cabinets. I cut out two holes for 120mm 12VDC computer fans so I have ~70 CFM of air handling in the amp cabinet.
    Now that I have a sewing machine (got to love pawn shops) I will custom sew my theater curtains. Thanks to the Mother-in-Law for all the sewing lessons :D
    Custom window drapes will be next. Jo-Ann Fabrics is your friend. You have so much more choice when it comes to fabrics and applique vs the big box stores (not to mention curtains there could easily run upwards of $1200-$1500 for what I want. Heck, 2 Roman shades (24X62) would have been $470 from Lowes:eek::confused:
    <a href="http://www.flickr.com/photos/33478047@N06/4518502368/&quot; title="PICT0093 by helpmmg, on Flickr"><img src="http://farm3.static.flickr.com/2715/4518502368_f630f4c8e1_b.jpg&quot; width="1024" height="768" alt="PICT0093" /></a>
  • PhantomOG
    PhantomOG Posts: 2,409
    edited April 2010
    acmf74 wrote: »
    I can vouch for Standout's quality and customer service. I purchased the Majestic Grand and it is by far the most beautiful and most high quality piece of furniture I own. It has a huge center channel drawer (holds my CSi40), vented glass shelves, temperature sensing fans, wire chase holes, thumb screw back panels.... all made in the USA with solid wood throughout.
    Sorry for the derail. If anyone does have questions about Standout just ask me.
  • kevhed72
    edited April 2010
    Lorthos wrote: »
    This was my preference originally, until I figured I had to place the TV in front of a window (which looks out to a beautifiul wooded backyard) for optimal acoustics. I still can't believe my wife bought off on that one...
    Cool posters by the way...
  • Slinger182
    Slinger182 Posts: 512
    edited April 2010
    Jinjuku that is awesome! Well done
    Panny 55-st30 plasma
    Pioneer vsx-1121
    Parasound 2100 pre
    b&k tx4430 amp
    Oppo bdp-83
    Monster HTS 3500
    polk TSi500s Vr3 Fortress modded
    polk CS20 center channel Vr3 Castle modded
    polk Owm 3 surrounds
    polk PSW505
  • kevhed72
    edited April 2010
    jinjuku wrote: »
    Now that is clever....the less I have to cut and assemble, the better...thanks for the idea.
  • Amherst
    Amherst Posts: 695
    edited April 2010
    Jinjuku... real nice. Like the set-up, it's clean and beautiful.
  • jinjuku
    edited April 2010
    Amherst wrote: »
    Thanks. A lot of people have been impressed. I was lucky. I picked up the cabinets from the guy that did my kitchen. He had two left over from another job. $50 for both:D $40 in ply wood, $6 in molding, $12 in drawer pulls, $8 for a quart of color matched paint.
    So about $120 for my entertainment furniture.
    Now just to get my ZDT 3.5's transferred from the MDF (beat up is the word) into the oak veneered cabinets I am working on.
