Anybody using or used an RTA8T for a center channel?
Conradicles
Conradicles Posts: 6,364
edited April 2010 in DIY, Mods & Tweaks
Seriously considering building a center to better match my SDA-2B's, and seems like an RTA8T would be a perfect match. I tried to search, but could not find any relevant information.
What y'all think?
Post edited by Conradicles on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited April 2010
  • lightman1
    lightman1 Posts: 10,797
    edited April 2010
    Well there ya go Eric! This should be a cool project. Keep me posted.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2010
    I think if you can find someone to split a pair of crs+'s it'll be the best match possible as they both us the same crossover, tweeter, and drivers.
    Just a thought.
  • Face
    Face Posts: 14,340
    edited April 2010
    leroyjr1 wrote: »
    Just a thought.
    This wouldn't work.
    There is something in the works, but other priorities are in the way.
  • Conradicles
    edited April 2010
    Looks like a got a lead on a set of RTA8T's. Might get them this weekend.
    I'm thinking:
    - Custom cabinet with black veneer. Extra bracing, but same internal volume
    - Use the same grill as the 8T (wonder if the logo can be taken off or turned 90 degrees?)
    - Upgrade the tweeter
    - Upgrade the capacitors and resistors
    - Use the same port from the 8T
    Anything else I may need to consider that I overlooked?
    heiney9 Posts: 25,487
    edited April 2010
    leroyjr1 wrote: »
    Just a thought.
    Why butcher a nice pair of CRS's to make a center channel when there are many other options? Plus the "SDA" portion won;t work so it's an exercise in futility.
  • leroyjr1
    edited April 2010
    heiney9 wrote: »
    Used the crs for my center for over a year with great results.
  • leroyjr1
    edited April 2010
    Conradicles
    I have a couple extra rta 8 crossovers you can have if you need them for your project.
  • Conradicles
    edited April 2010
    leroyjr1 wrote: »
    Thanks leroyjr1. Hold on to them for now, I'm good. I will have an extra one myself.
    If this project goes well, sounds great and looks living room presentable, I may offer to build a couple more for SDA owners so RTA8T parts will be needed.:cool:
