Anybody using or used an RTA8T for a center channel?
Conradicles
Seriously considering building a center to better match my SDA-2B's, and seems like an RTA8T would be a perfect match. I tried to search, but could not find any relevant information.
What y'all think?
What y'all think?
Post edited by Conradicles on
Well there ya go Eric! This should be a cool project. Keep me posted.
I think if you can find someone to split a pair of crs+'s it'll be the best match possible as they both us the same crossover, tweeter, and drivers.
Just a thought. -
This wouldn't work.I think if you can find someone to split a pair of crs+'s it'll be the best match possible as they both us the same crossover, tweeter, and drivers.
Just a thought.
There is something in the works, but other priorities are in the way."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Looks like a got a lead on a set of RTA8T's. Might get them this weekend.
I'm thinking:
- Custom cabinet with black veneer. Extra bracing, but same internal volume
- Use the same grill as the 8T (wonder if the logo can be taken off or turned 90 degrees?)
- Upgrade the tweeter
- Upgrade the capacitors and resistors
- Use the same port from the 8T
Anything else I may need to consider that I overlooked? -
Just a thought.
Why butcher a nice pair of CRS's to make a center channel when there are many other options? Plus the "SDA" portion won;t work so it's an exercise in futility.
Used the crs for my center for over a year with great results. -
Conradicles
I have a couple extra rta 8 crossovers you can have if you need them for your project. -
Thanks leroyjr1. Hold on to them for now, I'm good. I will have an extra one myself.
If this project goes well, sounds great and looks living room presentable, I may offer to build a couple more for SDA owners so RTA8T parts will be needed.:cool:
