SDA 1B Crossover for a Custom Center Channel
hangon
hangon Posts: 228
edited April 2010 in Wanted (WTB) Classifieds
I am looking to build a custom center channel out of all the drivers out of an old pair of SDA2B's.
Does any one have a used 1B crossover laying around for cheap?
Will it work without the Interconnect Cable like my 2.3tl's do?
My plans are to remove all the drivers from my 2b's and build a custom center channel with the same cubic inches from a single 1B.
Any help is appreciated.
HT Theater
SRS-SDA 2.3tl RDO's
Custom Center made out of a RTA15tl
Pioneer Elite SC-25 Receiver
CineNova Grande 5 channel Amp
Klipsch KA-1000-THX Sub Amp
(2)Klipsch KW-120-THX Subs
Basement System
SRS-SDA 1.2 upgraded Xover
ADCOM GFA 5500
ADCOM GFA 5503
Yahama P7000S Pro Audio Amp
dbx 120x-ds Sub-harmonic Synthesizer
2-JBL 4645C Subs
1-Paradigm SW2200 Sub
Klipsch Reference in wall's
Post edited by hangon on
  • Face
    Face Posts: 14,340
    edited April 2010
    That won't work at all. If you want a large, timbre matched center, look at the larger monitors(10, 11, etc...) or RTA series(11, 15).
  • Conradicles
    Conradicles Posts: 6,339
    edited April 2010
    I'm getting ready to build one out of a RTA8T to match my SDA-2B's. I need to research and see if it can be upraded to the TL status.
  • hangon
    hangon Posts: 228
    edited April 2010
    I thought that my SDA-2b's had the same drivers (MW6510). Man I was wrong they have (MW6503) and (MW6511).
    Darn I just sold an old pair of monitor 10'bs.
    Is there a huge difference between SDA-2b's vs 2.3tl's drivers? I am planing on installing 2 SL3000 from my 2.3tl's and not using the SL2000's from the 2b's.
    HT Theater
    SRS-SDA 2.3tl RDO's
    Basement System
    ADCOM GFA 5500
    ADCOM GFA 5503
    2-JBL 4645C Subs
  • Face
    Face Posts: 14,340
    edited April 2010
    For a center channel, keep it to a single tweeter unless you need the additional power handling.
  • hangon
    hangon Posts: 228
    edited April 2010
    Face wrote: »
    I agree, what about the monitor 12's crossover?
    Any one with an extra??
    HT Theater
    SRS-SDA 2.3tl RDO's
    Basement System
    ADCOM GFA 5500
    ADCOM GFA 5503
    2-JBL 4645C Subs
    Toolfan66 Posts: 18,040
    edited April 2010
    I like the idea of using a RTA 15t that would be one hell of a center if you have the space.
  • hangon
    hangon Posts: 228
    edited April 2010
    I have 65" width on top of my Big Screen.
    HT Theater
    SRS-SDA 2.3tl RDO's
    Basement System
    ADCOM GFA 5500
    ADCOM GFA 5503
    2-JBL 4645C Subs
  • hangon
    hangon Posts: 228
    edited April 2010
    Hook me up with your RTA 15tl's........
    HT Theater
    SRS-SDA 2.3tl RDO's
    Basement System
    ADCOM GFA 5500
    ADCOM GFA 5503
    2-JBL 4645C Subs
  • Conradicles
    edited April 2010
    Yeah, I'll take one of them too!
    edited April 2010
    You both what "one" of them?
