multi channel or digital hook up on older receiver
jay70
jay70 Posts: 3
I have been looking into upgrading to a new dvd player or blue ray and I have an older onky receiver TX-DS575 and was wondering if I should use the multi channel inputs on the back or just run the digital cable to the receiver? which will give me the best sound?
thanks for all the advice!!
jay
Post edited by jay70 on
  • hagmanm2
    hagmanm2 Posts: 205
    edited April 2010
    Living Room: Receiver: Pioneer Elite SC-25 | Turntable: Technics SL-B200 | CD Player: Rotel RCD-955AX | Fronts: Polk RTiA3 | Center: Polk CSi A4 | Rears: Polk FXi3 | Sub: Velodyne DPS-10 | Cables: AudioQuest Type4 & TypeA
    Office: Carver HR-742 | Speakers: RTi6 | Turntable: Numark 1600
  • apphd
    apphd Posts: 1,514
    edited April 2010
    jay, welcome to CP! It might depend on what you end up getting in your upgrade. Use the connection method that will utilize the gear with the best DAC.
  • PSOVLSK
    PSOVLSK Posts: 5,377
    edited April 2010
    If you get a BR player, you'll have to use the multi-channel for the new codecs. You'd obviously have to make sure the BR player has multi-outs.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited April 2010
    PSOVLSK wrote: »
    +1, this will be the option for getting the best sound. Multi-outs allow you to get Dolby TrueHD and DTS HDMA, using your Blu Ray player as the transport.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • hagmanm2
    hagmanm2 Posts: 205
    edited April 2010
    So Optical wouldn't allow you to utilize Dolby TrueHD? I didn't know that! :eek:
  • wutadumsn23
    edited April 2010
    hagmanm2 wrote: »
    Nope, only DD. HDMI is the best way to get HD sound, but 5.1/7.1 analog will work as well.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • jay70
    jay70 Posts: 3
    edited April 2010
    thanks for all the advice.
    jay
  • wutadumsn23
    edited April 2010
    NP Jay, good luck and keep us updated.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
