multi channel or digital hook up on older receiver
jay70
I have been looking into upgrading to a new dvd player or blue ray and I have an older onky receiver TX-DS575 and was wondering if I should use the multi channel inputs on the back or just run the digital cable to the receiver? which will give me the best sound?
thanks for all the advice!!
jay
jay
Definitely would go with Optical if you can.
http://www.bluejeanscable.com/store/digital-audio/index.htm
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10229Living Room: Receiver: Pioneer Elite SC-25 | Turntable: Technics SL-B200 | CD Player: Rotel RCD-955AX | Fronts: Polk RTiA3 | Center: Polk CSi A4 | Rears: Polk FXi3 | Sub: Velodyne DPS-10 | Cables: AudioQuest Type4 & TypeA
Office: Carver HR-742 | Speakers: RTi6 | Turntable: Numark 1600 -
jay, welcome to CP! It might depend on what you end up getting in your upgrade. Use the connection method that will utilize the gear with the best DAC.
If you get a BR player, you'll have to use the multi-channel for the new codecs. You'd obviously have to make sure the BR player has multi-outs.Things work out best for those who make the best of the way things work out.-John Wooden
+1, this will be the option for getting the best sound. Multi-outs allow you to get Dolby TrueHD and DTS HDMA, using your Blu Ray player as the transport.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
So Optical wouldn't allow you to utilize Dolby TrueHD? I didn't know that! :eek:Living Room: Receiver: Pioneer Elite SC-25 | Turntable: Technics SL-B200 | CD Player: Rotel RCD-955AX | Fronts: Polk RTiA3 | Center: Polk CSi A4 | Rears: Polk FXi3 | Sub: Velodyne DPS-10 | Cables: AudioQuest Type4 & TypeA
Nope, only DD. HDMI is the best way to get HD sound, but 5.1/7.1 analog will work as well.
-JeffHT Rig
Blu-Ray- 80 GB PS3
thanks for all the advice.
jay -
NP Jay, good luck and keep us updated.
-JeffHT Rig
Blu-Ray- 80 GB PS3
