Adcom 5802 amp and sda srs
ROY BOY
ROY BOY Posts: 89
edited April 2010 in 2 Channel Audio
Hi I like to know what is the best way to hookup Adcom 5802 to sda srs ?. I have one set of cable RCA to Balanced as well. Can I use RCA from pre amp to Balanced on power amp ?. Thanks Roy
Post edited by ROY BOY on
    heiney9 Posts: 25,497
    edited April 2010
    You do realize the 5802 is NOT common ground and add'l procedure's are needed?
    Plus I am not understanding your question based on how you've worded it. Also the RCA's have nothing to do with hooking to the actual SDA's.
    Please explain futhur
  • ROY BOY
    ROY BOY Posts: 89
    edited April 2010
    heiney9 wrote: »
    Hi. I know the 5802 do not have common ground and need to run wire in. Can I B wire speaker to amp or just used main only. The othe Q was about pre amp to power amp. Can I use cable from RCA out of pre amp to Balance in on power amp. Thanks
    edited April 2010
    I am sorry, and I don't mean this to be rude, but I can't understand your question. I assume English is not your native language.
    Go here Adcom
    and down load the owners manual, it will show you how to hook up a pre-amp.
    edited April 2010
    ROY BOY wrote: »
    Yes, with the proper adaptor(s) or if you have cables with RCA on one end and XLR on the other. Don't buy these special because you won't be getting any of the benefit of the balanced (XLR) connection.
    Why are you wanting to hook it up this way? Why not balanced to balanced or rca to rca?
  • ROY BOY
    ROY BOY Posts: 89
    edited April 2010
    heiney9 wrote: »
    Go here Adcom
    Yes English is not my native language and I am trying to know what is the best way to use that amp. I had blow up 5800 before because I did not know about the common ground. I am asking two thing in that post. # 1 did any one used RCA to balance cable to hookup pre to power amp ?. # 2 B wiring speaker to power amp have a good sound or just used singel wire. Thanks for putting up whit me.:)
  • ROY BOY
    ROY BOY Posts: 89
    edited April 2010
    heiney9 wrote: »
    Hi
    Just want to know if that is going to have any benefit. since there is none I don't need to take that road. Thanks
  • ROY BOY
    ROY BOY Posts: 89
    edited April 2010
    I just did the hookup and that is very nice amp. I did not do B wiring just regular and it sound very nice. Take care every one
    Toolfan66 Posts: 18,186
    edited April 2010
    You did tie the NEG's together on that amp "RIGHT"?
  • ROY BOY
    ROY BOY Posts: 89
    edited April 2010
    Yes I did. I did blowup 5800 before not doing that. Thanks for asking
  • NotaSuv
    NotaSuv Posts: 3,871
    edited April 2010
    good to hear all worked out...enjoy the amp and speakers...........
