cross over.
mhmacw
mhmacw Posts: 832
edited April 2010 in Speakers
what model is this? which model didi it come out of? where can i get 4 of them?
Post edited by mhmacw on
  • DollarDave
    DollarDave Posts: 2,575
    edited April 2010
    mhmacw wrote: »
    It might help us out if you told us where you got it?
    Why would you want 4 of them if you don't know what speaker they are the appropriate crossover for?
    At any rate, my guess (if that's what we are doing) is that they are from an S4 bookshelf speaker.
    [EDIT] I take my guess back - since the picture caption says it's a Bose, then that's probably what it is??
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2010
    Well...the caption says Bose crossover....
    If that's a Polk crossover though...I'm going to say that it's probably from a Circa 1991 Mini Monitor. The S4 is also a possibility.
    Where can you get 4 of them? I doubt you can, short of buying 4 of the speakers that they came out of, and removing them.
    What are you trying to do with them?
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • mhmacw
    mhmacw Posts: 832
    edited April 2010
    lol no they arent bose they are polk. they come out of a speaker from my wifes school. i want to put them in 4 bose 501's. but i dont know what to order. since they are going in bose cabinets they dont have to be that model just a 2 way crossover is what i need. i happen to have this so i snapped a photo.
  • DollarDave
    edited April 2010
    Hate to tell you, but it doesn't really work that way - you can't just pop a crossover into a cabinet that isn't at least similar to the originals, much less drivers that are probably of different impedence and frequency curve than what it was designed for.
  • Zitro
    Zitro Posts: 864
    edited April 2010
    Sell the Bose 501's, buy Polks, sit and listen.
    - Jeremy
    Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
    Speakers: Polk Monitor 7A's, KEF Reference 104aB
    Sources: ProJect Debut Carbon, Sonos streaming FLAC
  • mhmacw
    mhmacw Posts: 832
    edited April 2010
    i assure you its going to be better then whats there. this is a bose project and not a watch haha. all i need as something to seperate the lows from the highs ill worry about impedance on these things someother day. the photo is an example of what im looking for if anybody has 4 of any 2 way cross over they want to get rid of let me know.
  • mhmacw
    mhmacw Posts: 832
    edited April 2010
    i appreciate that dave but im looking for the type mounted to the speakerwire clamping plate. id like to find some of the re0805. ive tried it in one of the 501 cabinets and it didnt sound too bad.
  • mhmacw
    mhmacw Posts: 832
    edited April 2010
    thanks curt. its the larger s8 model. now i guess it comes to finding some eh haha. unless you might know of a schematic for the s8 crossover. i would build some.
    edited April 2010
    Zitro wrote: »
    Best advice right there. No time wasted.
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited April 2010
    Hello Mhmacw,
    You can find the S8 crossover schematic, posted by Dorokusai, in the Vintage section as a "sticky".
    Cheers, Ken
  • mhmacw
    mhmacw Posts: 832
    edited April 2010
    thanks ken. i must have skiped over it ill go look again. also, tony and zitro,thanks for the advice of getting polks but i already have and a bit finicky about what i add to my "keep" collection. i can assure you these 501s will not sit next to my 11t or 1c. i got them free and the woofers are done. the glass fuses and disk caps are shot. its going to be easier to set up a few crossovers and throw them in than all the proper research to set up a set of speakers i dont really care for. i bought 4 car sobwoofers so its going to be a home theatre sound anyway at the mom in laws place. thanks for the suggestions though if i was going to keep them id throw them out and get polks to match my others haha.
