Is My Room too small for Amazing Plats?
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2010
    Perhaps biamping would be the better way to go. I know when I biamp'd my 1.2TLs it brought the depth/separation/detail/bass response up to whole other level.
  • punk-roc
    punk-roc Posts: 1,150
    edited April 2010
    I was thinking about that, but is that possible with only one set of binding posts? Some of the Amazings have 2 pairs of posts... mine only has one pair however
    Jason
    2-Channel - So far...
    Pre: Dodd ELP
    DAC: W4S-Dac2
    Source(s): Computer and Denon 2910
    Amp: Parasound HCA-1200II
    Speakers: LSi9s - Vr3 Fortress Mod
  • hearingimpared
    edited April 2010
    punk-roc wrote: »
    Jason
    I don't know the answer to that one, perhaps you should put forth that question on the Carver Forum.
    http://www.carveraudio.com/phpBB3/index.php?sid=6102267cadeda1f110bc46be95e5cca3
  • erniejade
    erniejade Posts: 6,321
    edited April 2010
    Hold on... I thought the plats had 2..... Are you sure they are not originals, If they have a 60" ribbon instead of 2 x 30", but only 1 set of binding,,, it might have been an original converted to plats....
  • TNRabbit
    TNRabbit Posts: 2,168
    edited April 2010
    erniejade wrote: »
    Depends on which Plats. Some did, some didn't.
    They are originals converted to Plats if the woofers are the FLAT type (versus regular cone).
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • punk-roc
    edited April 2010
    i bought these from Shizelbz and i think he had a discussion with the forum too about what they were exactly. 60" ribbon, 4 cone woofers, one set of binding posts, pretty sure they are plats and thats what Shizelbz said too
    Jason
    Pre: Dodd ELP
    DAC: W4S-Dac2
    F1nut Posts: 52,007
    edited April 2010
    The Platinum's have two sets of binding posts, but no trim pots. The Platinum Mk IV has one set and has trim pots.
  • punk-roc
    edited April 2010
    touche, i meant i'm pretty sure these are plat mark iv's, thanks F1
    Jason
    Pre: Dodd ELP
    DAC: W4S-Dac2
    F1nut Posts: 52,007
    edited April 2010
    Jason,
    My post was meant to simply clarify, nothing more.
    You asked what speakers I thought would be better for the types of music you listen to and my answer would be SDA's except it's against the law to play hip-hop on them.
  • engtaz
    engtaz Posts: 7,669
    edited April 2010
    "You asked what speakers I thought would be better for the types of music you listen to and my answer would be SDA's except it's against the law to play hip-hop on them."
    Roflol
    engtaz
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2010
    if I had two tfm's I would be bridging them, never mind the peanut gallery...........lets fact it, you nor anybody else is going to know how you like it till you try it...........amps are like women, they're all good, especially on the inside, some though are just sweeter than a honey bee on a suckle rose.
    two RT1 demerits for eng and his hip hop bee bop cant stop makes my ears go pop doing the club polk rock.
    RT1
  • hearingimpared
    edited April 2010
    RT1
    Peanut Gallery Gestapo!!!:p I have to agree though, just because I had a bad experience with bridging amps doesn't mean I'm telling him not to try it. I should have made that clear.
  • punk-roc
    edited April 2010
    I probably will try it, its just lower on the priority scale now since many have said I probably won't get what I hoped out of the bridging. I'm gonna sneak some hip-hop into one of these Polkfests someday! hahahaha
    Jason
    Pre: Dodd ELP
    DAC: W4S-Dac2
  • reeltrouble1
    edited April 2010
    I used to bridge some NAD 2700 power envelopes with a set of 1C's, I had my fun with it for a while then moved on to the silver 9t's.
    You have to try stuff to get to know stuff.
    RT1
  • TroyD
    TroyD Posts: 13,124
    edited April 2010
    There is a gent on here that has been using a pair of bridged Carver's for a couple decades without a problem.....try it, why not?
    BDT
