Speakers for the Kitchen
drselect
drselect Posts: 664
edited April 2010 in Speakers
Need some help trying to decide on a pair of speakers for the kitchen. I will be using my pio vsx-d602s to power them and will be listing mostly to radio or cd. Trying to stick to a budget of $75-$100. Was thinking about a pair of atrium 45 vs RT-5 vs RT-25i vs M10 vs r150 ???. They don't need to be new. I currently have a pair of RT-25i in a HT setup to use as a comparison but don't necessarily want another pair. Wouldn't mind scoring a good deal on ebay. Would greatly appreciate your thoughts on any options. Thanks
Post edited by drselect on
  • punk-roc
    punk-roc Posts: 1,150
    edited April 2010
    I've had my eye on some of the Atrium's for sale at the polk direct ebay store.. Haven't pulled the trigger yet.. but thats what i was gonna do for the bathroom or kitchen system (I hadnt decided what to do yet)
    Jason
    2-Channel - So far...
    Pre: Dodd ELP
    DAC: W4S-Dac2
    Source(s): Computer and Denon 2910
    Amp: Parasound HCA-1200II
    Speakers: LSi9s - Vr3 Fortress Mod
  • drselect
    drselect Posts: 664
    edited April 2010
    Jason thanks for the reply. Have you had a chance to listen to the Atriums and if so how would you compare them to your R15?
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited April 2010
    For $100 I would try find some rti4
    The 4's sound amazing whilst being fed a signal thats less than perfection
  • GreggC
    GreggC Posts: 23
    edited April 2010
    I am looking for the same kind of setup - speakers for kitchen. I will look into the rti4s as well. Thanks
  • drselect
    drselect Posts: 664
    edited April 2010
    Thanks polkfarmboy for the suggestion. Hadn't even looked at those. Have spent a little time reviewing them and see that they are used a lot as rears but also get good marks for non Ht use. A couple of concerns I have rti4's so far are there size (how far the will stick out from the wall-wife factor), the cost of speaker mounts, and trying to find a pair for under $100....There are a couple on ebay for over $100 right now and from what I have read they are probably worth it. But part of the "fun" of this project was to stay in the budget I set unlike my last project were I went way over my budget.
    GreggC I call dibs on any rti4 that come up for less than $100 on PF or Ebay....:D:D:D
  • maximillian
    maximillian Posts: 2,149
    edited April 2010
    On a related note... any recommendations on a small-ish integrated receiver that is suitable for kitchen? Ideally it could mount under-cabinet, but I think this is something that won't be able to be found. Still, it needs to be small and inconspicuous. I need minimum an AUX for mp3 players and FM tuner.
    I have a 90's Technics receiver that would work and isn't too big. However, the WAF factor is high due to this being her domain.
  • drselect
    drselect Posts: 664
    edited April 2010
    Do you think I could replace two of my windows with the Carver Amazings that jereyj12 has for sale OR
    will my stove over power them and need to stick with some rti4?:D:D:D:D
  • Zitro
    Zitro Posts: 864
    edited April 2010
    Do they make integrated amps with tuners built in?
    Newegg has the M30's on sale for $99.99; I had a pair and they're great for that price. Don't know if they'll be too big for you or not.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16882290094&cm_re=polk_audio-_-82-290-094-_-Product
    - Jeremy
    Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
    Speakers: Polk Monitor 7A's, KEF Reference 104aB
    Sources: ProJect Debut Carbon, Sonos streaming FLAC
  • maximillian
    edited April 2010
    Already have Atrium 4's in the kitchen (thanks again Polk Audio!). I need a way to power them that has a tuner and mp3 player AUX input. I have an Accurian amp that works fine for these as an amp so a separate pre/tuner would work too. I can stick the Accurian out of the way and mount the pre/tuner under a cabinet. However, I don't see one that is easy to mount. I guess I could get a used Adcom pre/tuner, but it may be too big to look nice.
    My mounted Atriums:
    http://www.polkaudio.com/forums/showthread.php?p=1303527
    Recommendations?
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2010
    If it were me, I would go 4 speakers in ceiling. Nice kitchen by the way.
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited April 2010
    If you use 4 speakers in 1 room area wire them in a criss cross fashion so where ever you are you will be listening to stereo.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • drselect
    drselect Posts: 664
    edited April 2010
    I thought about in ceiling but was concerned about "spot" sound. It may have been the speakers I was listening to (not polk) but it seemed like when you stood under the speaker it was load and you couldn't hold a conversation with someone not under the speaker (They asked me why was I yelling at them and I was saying you need to speek up:confused:). Do the Polk in ceiling speakers spread the sound out? If they do which would be a good choice?
    Thanks for your suggestions.
    Scott, if I go with the 4 speakers I may get back to you for further clarification about the criss cross wireing.
