overpowered speakers?
lectronicjunkie
I have an Onkyo TX-SR805 on the way and I am worried about the recommended power for my speakers. I have RC65i's(Recommended Amplifier Power 20-100 w/channel) for my side surrounds, FXi A4's(Recommended Amplifier Power 20-125 w/channel), and Atrium 45's( Recommended Amplifier Power 10 - 80 w/channel). I know the front 3 will be fine(RTi10's & CSi5). As you know the 805 puts out 130 per channel.
This may be a dumb question but, am I going to be at risk of blowing these speakers? Any advice would be appreciated.
It's all in the detail.
:cool:
HT Setup:
Samsung PN50D550
Onkyo TX-SR805
Samsung BD-D6700
Fronts: RTi10's
Center: CSi5
Side surrounds: RC65i's
Rear surrounds: FXiA4's
Sub: Velodyne CT120
Outdoor: Atrium 45's
Pictures here
:cool:
HT Setup:
Samsung PN50D550
Onkyo TX-SR805
Samsung BD-D6700
Fronts: RTi10's
Center: CSi5
Sub: Velodyne CT120
Pictures here
Post edited by lectronicjunkie on
lectronicjunkie wrote: »I have an Onkyo TX-SR805 on the way and I am worried about the recommended power for my speakers. I have RC65i's(Recommended Amplifier Power 20-100 w/channel) for my side surrounds, FXi A4's(Recommended Amplifier Power 20-125 w/channel), and Atrium 45's( Recommended Amplifier Power 10 - 80 w/channel). I know the front 3 will be fine(RTi10's & CSi5). As you know the 805 puts out 130 per channel.
You are better off with more power from the amp than less power.
The bigger danger to speakers is an under powered amp and a user that likes to 'crank it up' to the point where the amp can no longer provide clean power and goes into distortion. Distortion & clipping the audio signal going to your speakers is what will damage your tweeteres.
Been there...done that...several times.:(
Your set up should be fine - unless you like going to 'stupid loud'
Thanks Erik. I do 90% HT so, I don't crank it up to deafening levels.It's all in the detail.
:cool:
HT Setup:
Samsung PN50D550
Onkyo TX-SR805
Samsung BD-D6700
Fronts: RTi10's
Center: CSi5
Sub: Velodyne CT120
Pictures here -
lectronicjunkie wrote: »Thanks Erik. I do 90% HT so, I don't crank it up to deafening levels.
Enjoy the sonic goodness! Beware though...once bitten by the upgrade bug you are doomed!
