Calibration and "The Polk Way"
section19
section19 Posts: 90
OK, I've got some speaker stands on order and they'll be here in a couple of weeks. So I'll finally have my speakers properly placed. No more sitting on top of old speakers, on top of tables, bookshelves, etc..
I have a neighbor who has a SPL meter and will help me calibrate my speakers. I told him I wanted to wait until I have them on stands. So I'll be giving him a call soon.
My question is how best to calibrate my sub since it's hooked up through the mains (The Polk Way). Since the sub setting on the rec. is set to "Off" I'm not sure how to isolate the sub from the mains for calibration.
I'm guessing that I should turn the sub off while doing the L & R mains. But then how best to disarm the mains while doing the sub? Set the test tone back to L main and disconnect the speaker while turning the sub back on so sound is only coming out of the sub, or what?
Obviously it would be easier if I had the sub cable hooked up. But I really do prefer the sound quality of "The Polk Way" so I figure I should calibrate if in this configuration if I can.
Thanks in advance to anyone who takes the time to respond.
Denon AVR-1803
Polk RM6700 w/ Infinity Entra Sub
Post edited by section19 on
  • petertkim
    petertkim Posts: 4
    edited November 2003
    I also have my 2 channel system connected the polk way. The easiest thing is to disconnect the speaker wires from the speakers when you're calibrating the sub.
    When calibrating the speakers (if they're already connected to the sub), just turn off the sub - the signals will go to the speakers even when the sub is off.
    Finally, adjust the low-pass with both speakers and sub on.
  • section19
    section19 Posts: 90
    Thanks, peter. I thought disconnecting the speakers might be the best way.
    Thanks, again.
    Denon AVR-1803
