2005 Toyota Avalon Speakers
Dan2036
Dan2036 Posts: 148
edited March 2010 in Car Audio & Electronics
I've been trying to figure out what speakers are in this Avalon and can't find it anywhere. I can't remove the covers on the speakers as it is part of the door. Does anyone know a way to find out ? I've checked the manual and google. They sound surprisingly good for the record.
TV- Samsung 24" LCD T240HD
5.1 Receiver - Harman/Kardon AVR 247
Stereo Receiver - Harman/Kardon 3390
Front - Monitor 60
Center - Cs10
Surround - Tsi100
Sub - SVS PB10-NSD :D
Playstation 3
Post edited by Dan2036 on
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited March 2010
    Try crutchfield.com They used to have a guide that would tell you what car has what speakers. Some of the other better online Auto electronic web sites also have a vehicle speaker application guide.
    Best of luck,
    dude
  • dudeinaroom
    edited March 2010
  • Dan2036
    Dan2036 Posts: 148
    edited March 2010
    Tried crutchfield.com and it didn't say. Really wish i could take off the door covers but it's the entire door.
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • Installer4life
    Installer4life Posts: 256
    edited March 2010
    You are probably looking at 6.5 in speakers in the front and rear doors. According to AllDATA these are your typical Toyota made speakers with adaptors built on to the speaker or rather part of the speaker. What that means is no speaker is going to drop right in you will need to make spacers, probably 3/4", to accommodate a 6.5 or 5.25 inch speakers. If it was my car I would pull the factory speaker from one of the front doors and one of the rear doors just to make sure.
  • Dan2036
    Dan2036 Posts: 148
    edited March 2010
    The thing is i'm not planning on replacing the speakers they sound really good, what i'm thinking is because I bought the car used the previous owner might have upgraded the system. That or I just have really bad ears and think factory speakers are good sounding :)
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • exalted512
    exalted512 Posts: 10,734
    edited March 2010
    So what exactly are you asking? If they're aftermarket or stock? Generally you can hold a light to the grill and see inside. If its stock, its going to be a plain black cone.
    -Cody
  • Dan2036
    Dan2036 Posts: 148
    edited March 2010
    basically if theirs anyway to find out without tearing the door off
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • Dan2036
    Dan2036 Posts: 148
    edited March 2010
    Ok well I tried to peek in with a flashlight, from what I saw even though it was difficult to see. It seemed to be shiny or reflective almost sparklie. No writing or anything else.
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • Dan2036
    Dan2036 Posts: 148
    edited March 2010
    Plus I think they're oval and silver with a two black drips from the center.
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • exalted512
    edited March 2010
    Definitely not stock then.
    -Cody
  • dudeinaroom
    edited March 2010
    The Avalon has 3 stock choices, standard, JBL, and JBL w/navigation. It is possible that you have a JBL system in there. Did you try to find sizes here?
  • Installer4life
    edited March 2010
    Your probably not going to be able to tell on that car unless you remove a door panel..
