IEC power cable upgrade
Tomasito
Hello,
I have a pioneer VSX94TXH elite. It's power cable is not the IEC detachable cable. Has anybody did a modification to an IEC.
The reason I am asking this, becuase I want the option to be able to upgrade the power cable.
thanks
thanks
Post edited by Tomasito on
I just did this with an amp a month ago. All you have to do is remove the stock power cord, measure and mark the hole for the IEC style receptacle, cut the hole with a Dremel or saw, screw in the receptacle and solder or crimp on the internal power wiring. It's a process that takes less than an hour. Good luck!
The IEC has 3 wires in it, but the pioneer amp has only 2 wires.
You can install a receptacle with 2 wires in it, or (check the schematic first) ground the 3rd prong to the case.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
If you go with adding a ground prong, you may hear some hum depending on the design of the amp. If that's the case, just lift the ground. -
ViperZ has a VERY VALID point. ALWAYS consult a schematic first. BUT the mod itself shouldn't be that hard.Onkyo TX-SR705 AVR
Onkyo M-501-Given to my father.
Onkyo DX-C730 CD Changer
Onkyo DV-BD507 Blu Ray player
Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
Polk Monitor 12's with RDO's and XO's
Polk CS300 Center
Polk Monitor Series 4 rears
EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek: -
My skills in reading schematics is very limited, I will play it safe and connect only 2 wires.
does it matter if I get the generic IEC socket or go with the really expensive furatech? -
These are not too bad in price>>http://www.soniccraft.com/products/connections/ac/socket/iec/furutech_fi10.htm
Easy to terminate too.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Hello fbm211,
thanks for the link.. I'll try one -
All I was trying to say is that make sure that your case is GROUNDED. Some (weird, unusual, old whatever) amp cases may not be grounded. So all you really need to do is measure the voltage between the case and the "real" known ground point on the boards.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
Hello Jake,
Did you hear and improvement/change in sonic quality? -
I just ordered some stuff from PartsExpress to do this exact same mod to an Adcom amp and preamp, both with stock, non-detachable power cords. Neither of these components have a grounded 3-prong plug, so I will try both ways and see what happens.
Sorry for the derail, just figured I'd chime in and let the OP know that this mod is probably not a
bad idea.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
deletedSo, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
deleted
Don't understand what deleted means.
Don't forget to post results of the modification. -
I accidentally hit the "submit" button twice (didn't even realize it, either
So I edited the 2nd post while I was still able to, that's all.
As soon as I get my order from PEx, I'll be ready to do the mod... good thing I have two Adcom 535s to play with
