Voight pipes
Anybody have any listening experience with them? What's the general consensus? Just curious...
http://kosat.consultit.no/~ketil/lowther/voigtpip.html
Post edited by rs159 on
It depends on what driver you use in it.
Lowther ($$$$), Fostex ($$), Pioneer/Ratshack ($)....
Check the partsexpress project showcase, they feature a 2-way model.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Russ, seems like you fancy the cheapy Pioneer 8" in a VP, eh? From what I've read it isn't terrible but then I didn't look very hard
Not to say Lowther isn't nice; but, you know - $$$$
edit - seen the PE project before - crossover, blech! These things are supposed to be cheap and simple!
I was going to build a pair before I made my periscopes. I'll still build them someday though.
I've heard a few pair. They all sounded good. Some even sounded great.
http://cain-cain.hypermart.net/audio/abby/index.html
These sound great. A few hundred bucks for wood and Fostex drivers and you're golden. If you want to experiment with less expensive drivers first, I wouldn't blame you. Check your local Radio Shacks and see if they have any full range speakers left.
Good luck.Make it Funky!
More reading material.
http://www.melhuish.org/audio/enclosuretqwt.htm
Check out Martin King's stuff. Very thorough site.Make it Funky!
