I need a budget preamp, any ideas?
Bigbang
Help,
I'm looking for a preamp to sit between my squeeebox duet and my Adcom GFA-555. I dont have a need for phono and the SQB is my only source. I'm outputing to sda 1c's.
Does anyone have suggestions or possibly something to sell?
Thanks in advance.
David
Thanks in advance.
David
I like to listen, tinker, listen and repeat.
Post edited by Bigbang on
Please elaborate on "budget".Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Look for an older Parasound.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Not to jack this thread, but how about under $500 and in tube or SS?
Ben, you still got those chickens? -
Thanks Ben and Leroy. Parasound looks like a nice device with good circuitry and an Adcom might have good synergy with the 555. I'll try my luck with CL and the for sale forum here.
No problem on th HJ Hill. I'll have to upgrade sometime.
On to the hunt.
Thanks guys!
DavidI like to listen, tinker, listen and repeat. -
Hi,
I have a Superphon Revelation pre amp that I am putting up for sale for $150. It has a seperate power supply and has 2 inputs and 1 phono input. It sounds good and works well. LMK if you are interested. I am going to post many things this weekend. ThanksMain system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
If you can go a little more you might want to consider the Maverick Audio
I've heard some really good things about it.
http://www.mavaudio.com/base/Main 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22 -
I would llok for a used Parasound or B&K. Good luck.Anthem D2v
NAD M50 Music Server
B & K Reference 200.5
Parasound A21
B & W 804 (Mains)
B & W HTM1 (Center)
Polk Rti4 (Surrounds)
PS3
Seaton Submersive HP
Pioneer PDP 6010FD Kuro -
Any suggestions on the model of the Parasound? Considering the setup.
Thanks again.
Sometimes you can find B&K Reference 10's or 20's for decent prices on Ebay. Just put them in stereo mode and they make a great sounding pre.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
Do you need an active preamp or just an attenuator and/or switch?
If a passive attenutor/switchbox is all you need...
http://www.audiokarma.org/forums/showthread.php?t=155993
http://www.audiokarma.org/forums/showthread.php?t=134447 -
Get the Carver CT-28v, which is currently in the flea market. That's a bargain and an awesome preamp. It handles 2-channel duties very well, plus it comes with the remote.
I used to have 1, and the only reason I sold it is because I was using my Carve C-1 more than CT-28v.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Once again we meet at last.
Either that ps audio one starkoller is selling or the parasound 850
You might want to consider an Acurus L10. It's got pretty high build quality and great sound. It also uses fairly high end components, considering it can be had for around $125.
I'm using one with an Adcom GFA-545 driving a pair of SDA 2A's...and it sounds fantastic. It made for a VERY big improvement over the Onkyo 606 I'd been using before that.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I have a Parasound P/SP 1500 Preamplifier that I'll let go for 95 bucks. Comes with remote control and owner's manual. Has stereo direct mode as well as surround mode.SDA SRS 2.3TL's
SDA 2B TL's
