Help
over50
over50 Posts: 201
Do Acoustic Panels help much? I have seen these on the showcase, and i was wondering if the are worth adding these to my system. I`ve looked on line and i could buy a pair for not a lot on money. I would appreciate any info . i have a 6.1 system with monitor 60 front, center cs2, psw505,monitor 40 rear, and cs10 rear surround. Thanks in advance for the input. I was considering putting the behind the
M60`s.Thanks
Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
B&K ST.3140 Power Amplifier
HSU Research VTF2 MK3
Vizio P65-C1
Panasonic 605 blu ray
Onkyo DS-A4 i-pod Dock
Universal Remote
BDI Icon 9429 TV Stand
  • packetjones
    packetjones Posts: 1,059
    edited March 2010
    I do not have any and do not really know much about them so take my opinion with a grain of salt.
    From what I have gathered in reading, they "can" make a great difference. It depends on where they are placed as well as the room they are in. I have also read that bass traps work great as well.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • over50
    over50 Posts: 201
    edited March 2010
    Thanks for the reply. I have also read that about bass trAPS.
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    Vizio P65-C1
    Universal Remote
  • sandworms
    sandworms Posts: 1,043
    edited March 2010
    there's a ton of data on this, maybe, someday, waf willing,I will get this for my room. if you check out http://auralex.com/ they can guide you with their tutorial even if you don't use the product. theres also a ton of info at http://www.avsforum.com/avs-vb/forumdisplay.php?f=19
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
