LSi F/X placement ????
CoolFrenzy
CoolFrenzy Posts: 2
I am adding two LSiF/X speakers to make a 7.2 system. The F/X speakers are behind my seating position.
Do I put the 'Left' speaker to my left, behind me (when I am facing forward) ?
Does it matter when I run them in Bipole mode ?
Post edited by CoolFrenzy on
  • jimmydep
    jimmydep Posts: 1,305
    edited March 2010
    While facing forward (toward the main speakers), the left speaker would be on your left behind you.
  • CoolFrenzy
    CoolFrenzy Posts: 2
    edited March 2010
    Thanks jimmydep
    This reverses the speaker position relative to each other.
    When the speakers are in front (or beside) you (with the Left speaker on your left), the left side of the Left speaker is pointed toward the Right speaker.
    When the speakers are behind you, and the Left speaker is on your left then the right side of the Left speaker is pointed toward the Right speaker.
    Running the F/X speakers in a Bipole configuration (where both sides of the speaker fire together), I don't think it matters. Unless I am missing something.
    Running the F/X speaker in a Dipole configuration it would alter the intended 'dead zone'.
  • acmf74
    acmf74 Posts: 937
    edited March 2010
    I recently picked up a pair of the FXs.. Should they be placed ear level or higher?
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited March 2010
    Typically you would like any speaker to have the tweeter about ear level for best results, but with surrounds it is sometimes difficult due to limited mounting options. Get it as close as possible and you will be fine, esp. with the LSi FX.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • reberly
    reberly Posts: 173
    edited March 2010
    If you read any of Polks how-to articles they say rear surrounds should be at least 2 feet above and behind your ear. There are detailed instructions for bipole and dipole settings
    Onkyo TX-SR805
    Polk LSi15 , LSiC, LSiFX
    Parasound Halo A52
    Panasonic 42'' Plasma
    Oppo BDP-83
    Sonos
    Panamax 4300
    Audioquest cables
