Protable Music Player for SQ
skrol
skrol Posts: 3,463
edited April 2010 in 2 Channel Audio
The thread about the lossless downloadable music got me thinking.
http://www.polkaudio.com/forums/showthread.php?t=99026
Who makes a decent sounding (mp3, i-pod like) portable music player? I have listened to a few mp3 players and they seem to be a compromise in SQ and can even sound worse with quality headphones.
Name your preferred device:
Stan
Main 2ch:
HT:
Other stuff:
Post edited by skrol on
  • 98Badger
    98Badger Posts: 317
    edited March 2010
    I have a Sony Walkman (it's a couple years old) and find the SQ to be significantly better than the ipods (not like that is difficult). The drawback is that it doesn't play flac and is fairly limited on usable formats. If you plan on using mp3, it's worth looking into. I'm waiting to upgrade until I can find a reasonably priced player with a ton of memory that plays flac or wav. The Archos 5 looked promising, but I have read a mountain of negative reviews about functionality and they cost quite a bit. I'd love the 500 gig model if it worked right.
  • phipiper10
    phipiper10 Posts: 961
    edited March 2010
    I haven't checked recently but the creative labs sounded better than the ipods and the s/n ratio was much higher I believe as well.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited March 2010
    Good sound....http://www.redwineaudio.com/products/imod
    ipod that has been imodded.
    Has to be the correct ipod though to have the Wolfson DAC.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • skrol
    skrol Posts: 3,463
    edited March 2010
    Now that is interesting.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • bikerboy
    bikerboy Posts: 1,235
    edited March 2010
    You didnt say what file type you want to use. I use flac files and think I will be getting a Sansa clip+ soon. It plays flac, mp3 ect. I think I will get a 2gb and a couple of 8gb cards to go with it. That way if the player dies I will out less $. I can also use the different cards for road trips ect. One card for my music and one card for my wife.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • skrol
    skrol Posts: 3,463
    edited March 2010
    I didn't realize that the Clip+ did flac and had a micro-SD slot. My wife has the original Clip and it is decent.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,463
    edited April 2010
    I just picked up a Sansa Fuze 8g. The SQ is very impressive for such a small device even playing 192kbps MP3s. With my Denon AH-C751 in ears, the music is warm, balanced, and detailed.
    Thanks for the Sansa recommendation.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • hagmanm2
    hagmanm2 Posts: 205
    edited April 2010
    phipiper10 wrote: »
    +1 Creative players have always had excellent build quality to them. I had a creative zen touch for the longest time (big and bulky comparatively, but excellent quality). Have since upgraded to an Ipod Classic for the convenience. *sigh* they are so damn convenient though. And at least I can convert my FLAC to Apple's Lossless...
    http://www.creative.com/products/mp3/
    And if you want one more on the cheap, their older Creative Zen Vision (or Zen Vision M) are great deals too!
    Eeeeebaaay
    Living Room: Receiver: Pioneer Elite SC-25 | Turntable: Technics SL-B200 | CD Player: Rotel RCD-955AX | Fronts: Polk RTiA3 | Center: Polk CSi A4 | Rears: Polk FXi3 | Sub: Velodyne DPS-10 | Cables: AudioQuest Type4 & TypeA
    Office: Carver HR-742 | Speakers: RTi6 | Turntable: Numark 1600
  • headrott
    headrott Posts: 5,496
    edited April 2010
    Yes, I own a Creative Nomad Jukebox 3 player. The 40 GB one and use it for .wav files to listen to when I go backpacking. It has the best S/N ration ever produced in a portable digital player. It sounds very good for something that is portable and convenient. I recommend a Creative player as others have suggested.
    Greg
