What's the correct way to use SLM ?
newsman
If you were wondering, SLM is a Sound Level Meter. I'm using one from Radio Shock, I know how I need to set it but was wondering should I point it towards the ceiling at all time or should I point it to the corresponding speaker when it emits test tone.
Post edited by newsman on
when i did my calibration i screwed it onto a tripod put it on the sweet spot and fired it at the ceiling at the same level my ears are while sitting down..
seemed to work out goodSpeakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2 -
Great idea for setup with the meter ntculenuff. It would seem to be the most accurate way to do the setup. I think I do mine over the way you suggested.Chris
I put it on tripot located in the sweet spot and pointed at speaker to be set, same level while seated .(worked ok )
I point my SLM up toward the ceiling. I place it on a tri-pod like others in the sweet spot and set up each speaker one at a time using the test tone from a set up DVD. It makes a big difference once all your speakers are set up with the correct level coming out of them. I was a little skeptical at first.. but once i did it and then listened to a CD and DVD i was hooked. SLM are pretty cheap or borrow one from a friend. It does make a difference to find out how off your speaker settings were.PolkFest 2012, who's going>?
I have it in center of room, or center sweetspot at ear level and it slightly upwards and toward each speaker being tested. I read this some where and it worked great for me. Calibrated at THX sound levels(if your speakers can acheive it that is) I think it was 80db speakers and 120db sub.
yup, set to 80dbPolkFest 2012, who's going>?
