pioneer VSX-55TXi and osd?
roystr
roystr Posts: 13
edited November 2003 in Electronics
i can not get the on screen display to work.
or it works,but i just cant see it. or its not abled,but i didnt dis able it,nor do i know how,nor have i read how to able/disable it.
we are re-reading the manual. the dvd player works.the vcr works. the tuner works............as far as i can tell,it all works except the on screen display to guide me through the suround set up.
any ideas??
thanx folks,
roy
Post edited by roystr on
  • dorokusai
    dorokusai Posts: 25,576
    The Sony ES has OSD also. The OSD only works, on Sony, when you connect a Composite Video cable to the "Monitor Out" connection. It will not OSD thru the SVideo/Component/Etc. connections. Try that perhaps.
    FrankZ had a Pioneer, he may catch this thread.
  • roystr
    roystr Posts: 13
  • mantis
    mantis Posts: 17,453
    Check it out,
    run a composite or S video out of the monitor out of the receiver.Put the TV on the correct input.Then hit the setup menu..............ALLDAY onscreen display.
    Dan
  • roystr
    roystr Posts: 13
    "run a composite or S video out of the monitor out of the receiver.Put the TV on the correct input.Then hit the setup menu..............ALLDAY onscreen display"
    what does that mean in english...more or less............ill take less for now
    msg me @ roystr@hotmail.com
    anyone anyone call me and help me me please..............
  • aba4430
    aba4430 Posts: 80
    Roy,
    The video cable from your sources must be the same type as the video cable connected from the "monitor out" jack on the Elite to the monitor. If your Elite has video upconversion, then your settings may be in error. I have the 47TX, so I do not have the upconversion, but found out that the DVD player connected via a super video cable (or component video) and monitor via an RCA video cord does not work.
    Regards,
    aba4430
  • roystr
    roystr Posts: 13
    frank on
    http://forums.klipsch.com/idealbb/view.asp?topicID=40980&pageNo=1&num=30&sessionID={C0E5E7D2-CCD6-4273-A9E0-F29253DA49B9}
    helped my wife teresa do it. if anyone has a problem hooking up the on screen display without a new tv set, this is the way. e-mail teresa at
    teresa88@hotmail.com
    be nice, she is my ole lady,but smarter,and stronger than me.
    she is 6' tall and can toss me about with ease... i love it, lol
