help with my yamaha rx-v1900 and polk tsi speakers
hi, i have a yamaha rx-v1900 w/ some polk tsi speakers and a psw 505 sub. I want to listen to my 5.1 setup while listening to tv but it only gives me the L R option, when i first set it up it was showing all the speakers and they were shownas in (RED) on the reciever's screen, now they are yellow L R as stated. I went through the manuals but couldnt find n e thing. Can some one who owns a yamaha a/v show me the steps to do this, keep all my speakers on at all times?
Post edited by josereyna on
Welcome to Club Polk Jose, do you by chance have a HD cable/satellite box? IIRC, most TV broadcasts are formatted in 2 ch. stereo and unless you choose a sound format on your AVR that will matrix the sound to the other channel, that will be all you get. With the exception of the HD channels, the are DD 5.1. Does it work in 5.1 in other modes, such as DVD/Blu Ray? I'll look into the AVR's specs. and see what I can find for you.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Jeff is right!
But as a follow up question. How do you have your TV or Sat/cable BOX connected to your AVR? I'm assuming it's HDMI or Coax or toslink? Right!
Good point C, the connection is key as well. A little looking around on Google has led me to believe that is a more than capable AVR and you should be able to switch to a different listening mode to matrix the sound to the other "unused" speakers.
-JeffHT Rig
Blu-Ray- 80 GB PS3
You're right Jeff,
Personally I'm not a big fan of Yamaha AVRs..BUT the higher models are really worth looking at and listening to--starting with the 1900. I don't think you can do wrong with that!
On my 3900, those lights show the signal from your source. A 2 channel source such as most cable channels will only light up the L / R lights. You'd need a 5.1 source to light them all up. You can still listen through all your speakers by selecting one of the surround modes on your AVR.Primary System
Polk Audio SDA SRS 2.3TL (RDO198,Sonicap/Dayton/Mills,CardasCCGR,Mye Spikes,DynamatX,Driver Rings,Ben's IC,Bi-Wired)
Polk Audio CSiA4 x2 (C)
Polk Audio FXiA6 (S)
Polk Audio RTiA3 (RS)
Polk Audio FXiA4 (FX)
Epik Sentinel x2
Yamaha RX-V3900
Rotel RB-1090
Rotel RMB-1095
NAD C565 BEE
Technics/KAB SL-1210M5G w/ Denon DL-160
Parasound Halo P7
OPPO BDP-83
Panasonic TC-P65V10 65" Plasma
