Monitor 5B's given a refurb & upgrade w/pics
geoff727
Hi everyone. Here is a pair of Monitor 5's I just finished working on for a good friend I work with. He wanted something inexpensive that sounded and performed fairly well. I said, "I think I might have the ticket for you". So we found these that night on ebay. Here's what they looked like when they arrived (all the drivers were in, BTW).
Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS-II (modded)
Infinity RS-IIIa (modded)
Infinity RS 2.5 x 2
Magnepan 1.6QR (modded)
System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
And here's something that always bothered me a little bit, the "mistolerances".Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373 -
Here's a few pictures in process. I filled in all of the gaps between the black melamine front panel and the veneered edge bevels, so it's much more of 'finished' look now. Crossovers, binding posts....all the standard stuff.Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
Here's what they look like now. The veneer is maple. The drivers have new mounting hardware, all stainless w/ T-nuts.Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
Reclothed grilles, redone grille badges, binding post cups with new hardware, a lustery finish, and veneered/finished back edges.Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
Nice job!!!!
Was the veneer process hard? -
And a few more, plus the basic cables I assembled for my friend for his new music system.
Hope you all enjoy!
GeoffPolk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
Two more...
You'll probably notice that many of the holes on The PCB are re-drilled to move things around enough to enable a nice, strong, stable, mounting to the new components.Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
Geoff,
Beautiful work. Looks like a brand new set, and I know that you took your time and did it right.
Are those t-nuts very difficult/pain in the **** to set in the MDF?
NathanHome Rig
SDA 2.3TL's front and center
Polk 1000p Center
Pioneer Elite SC35 Receiver (Pre/Surround
Sunfire Cinema Grand 5X200-Back in the mix.
OPPO BDP-93
Squeezebox
Stepped up to name brand Speaker Cables and interconnects!
Monitor 4, 5, 7, 10's, SDA 1B's, 2B's, 2.3TL's, RTA 15TL's all in storage waiting for me.
Sales Rating #1!! -
Leroy....yes, they're a little time consuming. 20 separate pieces of veneer on each cabinet (front, bevel, side, back edge, inside back edge x 4 on each cabinet).
Nathan...great to hear from you! I've been wondering if you still had the 2B's & 2.3tl's. After I sold all my Polk's off last year, several months later I really started missing them (even though my current system is technically superior in all areas). So, I recently sprang for some RTA 15tl's and just yesterday for some beautiful Monitor 10 Series 2's. The workshop will be busy, that's all I can say. And, I plan to pick up KC's (kcoc321) 7C's as well. I'm hopeless.
A T-nut can be a little tricky to line up perfectly in the particle board (it's not MDF, which is much finer). Usually I have to insert a long screw into it and tap it into place while keeping the screw straight up and down.
Take care,
GeoffPolk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
Geoff, those mon 5's look great.. your work is nothing less than top notch. your friend will be so happy with those. collector items if you ask me.PolkFest 2012, who's going>?
FWIW, I actually had a "punch-list" of 28 separate items for these. Including, repairing a separating seam on one of the bottom corners. I had to remove a bottom bevel, and part of one of the side bevels to get in there, clean thngs out, and re-set the joint.Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
danger boy wrote: »Geoff, those mon 5's look great.. your work is nothing less than top notch. your friend will be so happy with those. collector items if you ask me.
Thanks Al! I still need lots of practice w/ veneer, though. I'm thinking about doing the Mon 10's in ebony or cocobolo.Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
Geoff,
Thanks for the heads up. Yep, still have them, they are in the same shape as when you and I wrapped them up. Sitting in my nephews house, waiting.
Glad to hear that you have been unable to completely escape the lure that is vintage Polk.
I have wanted to put my ears on a set of 15's, let me know what you think.
NathanHome Rig
Polk 1000p Center
OPPO BDP-93
Squeezebox
Sales Rating #1!! -
WastelandWand'r wrote: »Geoff,
Nathan
I'm glad you still have them. I don't miss the 2.3tl's, but I sometims think about the -2B's. I think they have real potential. If I were to ever get another SDA, that would probably be it.
These 15's have bad tweeters, and a few cabinet dings. That's the kind of buy I like to make....just enough problems that the seller is willing to let them go cheap! It'll be a long time before I get to them. I have two other Infinity's (same ones you saw tucked away in the corner) that are mid-project and I really need to take the next year and get those things done.
Now if i can just hold on at my job, I'll be doing fine! :rolleyes:Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
This is the difference in the look with the production gaps finished off. It's just one of those nice touches, I think.Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
Those look great Geoff, but then I would have expected nothing less, given the previous projects I have seen.
Very nice veneer job, Geoff. How did you remove the vinyl?
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
Jim
Very simple. A heat gun and some type of scraper.Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
Geoff,
Those look fantastic!!! Very nice work. Looks like you took your time and did all things right.
Beautiful bro just Beautiful...
Larry. -
Hi Geoff, Nice job. I was wondering what you filled the gaps with and how hard was this to do. I'm going to do some 1B's and noticed they have the same gaps that you had and have been trying to figure out how and what to fill them with. Thanks in advance for your help
Nice work Geoff, those look fantastic. I wish my Monitor 5's looked like that.Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
Beautiful and thanks for the pictures. Maybe this will inspire some to do the veneer on their vintage Polks.
Again, great job! -
Thanks for the compliments, everyone!Hi Geoff, Nice job. I was wondering what you filled the gaps with and how hard was this to do. I'm going to do some 1B's and noticed they have the same gaps that you had and have been trying to figure out how and what to fill them with. Thanks in advance for your help
It's not difficult, you just have to go slow and use care that you don't accidentally do any damage to the black melamine. For a lot of the gaps, you can run a thin strip of veneer into the gap. Once the glue is dry on it, you just level it off with the front bevel face and veneer over the top. Some gaps are really big (wider than the thickness of veneer), so you can run the veneer strip into it with a liberal amount of glue, and use LOTS of tiny wedges to kep that strip planted firmly against the melamined surface. For these thick gaps, you have to do this to prevent the wood glue from sucking that small veneer strip back away from the melamined surface as the glue dries and shrinks in size. Other gaps are really thin and are best filled with wood putty, carefully sanded, given a hair of black paint, and veneered over.
Basically, whatever creative method you can come up with is what works!
Probably a thousand different ways would work fine.
GeoffPolk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
Geoff
They look fantastic. How do they sound?
I see that you lined the entire interior with Sonicbarrier, or something like it. How was the original Daycron batting placed? Did it fill the entire cabinet?
StanStan
Main 2ch:
HT:
Other stuff:
Yes, the lining is Sonic Barrier. After about 2 hours of listening last night, I actually decided to remove half of the original polyfill. I had first reassembled them with the original polyfill rolls. But, having to pack it in there fairly tightly, I felt that it started to dig into the bass response a bit; I had the impression of passing the point of increasing the 'apparent enclosure volume' to definitely decreasing it. That's not based on any measurements, just a subjective impression. Anyway, the remaining half of the polyfill, I just lightly bundled and spread out within the enclosure. I'm a bit more satisfied with the bass end now.Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
The 5B's getting the run-through and new components broken in. Sure is nice to listen to music through these again. Everything else is pushed off to the side for the time being.Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
Amazing work, Geoff!! It is great to see vintage Polks transformed into 21st century collector speakers. Thanks for posting your pics!HT in Progress
Receiver - Harmon Kardon AVR520 5.1
Fronts - Polk SDA 1C
Center - Polk CS350
Monitor - Sharp Aquos LCD
NMT - Mede8er500x
Cables - Signal Ultra -
Forgot these two pictures of the tops, one with a flash and one with normal light.Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
Hey, like your new rack and are those new subs too
Geoff, phenominal work there!--Gary--
