Cleaning speaker terminals
acmf74
Is there a specific solution to clean the terminals, or can I use a household product?
Thanks!
Thanks!
Post edited by acmf74 on
A good option would be Caig Deoxit to clean.Deoxit gold to protect.
The stuff is not cheap however.But it will last a while.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Hello, many folks including me use a product called Caig De-Oxit and De-Oxit Gold religiously for optimizing and cleaning electronic connections. It can be ordered online or found at your local Rat Shack.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Fry's carries it now too in every size available.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
A link to the Caig DeoxIT site.>>http://store.caig.com/SDA-2BTL with custom IC
