New! - Denon DRM-800A
skrol
skrol Posts: 3,450
edited April 2010 in 2 Channel Audio
I just picked up a NEW Denon DRA-800A for a song. Apparently a church had bought a sound system back in the day (ca. 1991) and including this deck but tucked it away and never used it. I do church sound and it happens. It came in the original box and packaging and not a scratch on it.
I did a quick check to see if it plays and it does. My question is; given that this deck has sat unused for about 19 years, is there anything I need to do / check before I put it in service?
Stan
Stan
Main 2ch:
HT:
Other stuff:
Post edited by skrol on
  • thuffman03
    thuffman03 Posts: 1,325
    edited March 2010
    Most likely the belts are going to need replaced.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • skrol
    skrol Posts: 3,450
    edited March 2010
    Good point. They may also be misshaped due to sitting the same position for so long. Maybe I'll do a burn-in with some tapes that I don't care about to see if there is any issue of slippage, breakage or instability.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,450
    edited April 2010
    I haven't changed any belts as I have not been able to locate any. They seem in good shape anyway. After a good cleaning (lots of nasty film all over due to the foam packaging deteriorating) and some bench testing, I hooked the DRM-800A up to my main stereo. I played some previously recorded tapes and recorded one with this deck. All I can say is this thing is sweet. The tonal quality and the transient are fantastic. This is truly the best cassette deck that I have experienced.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
