New! - Denon DRM-800A
skrol
I just picked up a NEW Denon DRA-800A for a song. Apparently a church had bought a sound system back in the day (ca. 1991) and including this deck but tucked it away and never used it. I do church sound and it happens. It came in the original box and packaging and not a scratch on it.
I did a quick check to see if it plays and it does. My question is; given that this deck has sat unused for about 19 years, is there anything I need to do / check before I put it in service?
Stan
Stan
Stan
Main 2ch:
HT:
Other stuff:
Main 2ch:
HT:
Other stuff:
Post edited by skrol on
Most likely the belts are going to need replaced.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
Good point. They may also be misshaped due to sitting the same position for so long. Maybe I'll do a burn-in with some tapes that I don't care about to see if there is any issue of slippage, breakage or instability.Stan
Main 2ch:
HT:
Other stuff:
I haven't changed any belts as I have not been able to locate any. They seem in good shape anyway. After a good cleaning (lots of nasty film all over due to the foam packaging deteriorating) and some bench testing, I hooked the DRM-800A up to my main stereo. I played some previously recorded tapes and recorded one with this deck. All I can say is this thing is sweet. The tonal quality and the transient are fantastic. This is truly the best cassette deck that I have experienced.
StanStan
Main 2ch:
HT:
Other stuff:
