Okay boys, what do you think??
woodhead 2
My warranty on my DLP is going to run out next month. Is it worth it to pay 100 bucks for another year, or should I hope they made a good product and pass on the warranty. How many of you go for the extended warranty??? Thanks.
Art
Art
Panny 8000 project
Oppo 103D
Fronts- Monitor 70's
Upper fronts- Monitor 30's
Surrounds- Monitor 50's
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
Onkyo 607[back up]
Oppo 103D
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
Onkyo 607[back up]
Post edited by woodhead 2 on
I typically don't buy the warranty on stuff, but on something very expensive like that I usually do. Typically, around $1500 is usually where I draw the line.
I just bought a new washer dryer set for almost 2K, and decided to pay the $169 through the warranty through Best Buy. -
I never buy an extended warranty. IMO waist of money.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
For $100 it is not bad. I would say if you are not good with fixing electronics then get it. I did not have the warranty on my dlp and have had to replace the lamp as well as the color wheel. It is basically like opening a computer and fixing something. If this intimidates you then get the warranty. If not you should be able to fix anything that goes wrong with it.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
I know I wouldn't have a problem changing out the lamps, looks pretty simple. Maybe I will just take my chances, and say hell with it. Thanks for your responses.:pPanny 8000 project
Oppo 103D
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
Onkyo 607[back up] -
I had a mitsy DLP bought the warrenty as it was new technology at the time it paid for power unit. Also check the SVS forum for your set it'll give you a good idea for what to do. Good luck
Paul
