Okay boys, what do you think??
woodhead 2
woodhead 2 Posts: 367
edited March 2010 in The Clubhouse
My warranty on my DLP is going to run out next month. Is it worth it to pay 100 bucks for another year, or should I hope they made a good product and pass on the warranty. How many of you go for the extended warranty??? Thanks.
Art
Panny 8000 project
Oppo 103D
Fronts- Monitor 70's
Upper fronts- Monitor 30's
Surrounds- Monitor 50's
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
Onkyo 607[back up]
Post edited by woodhead 2 on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited March 2010
    I typically don't buy the warranty on stuff, but on something very expensive like that I usually do. Typically, around $1500 is usually where I draw the line.
    I just bought a new washer dryer set for almost 2K, and decided to pay the $169 through the warranty through Best Buy.
  • thuffman03
    thuffman03 Posts: 1,325
    edited March 2010
    I never buy an extended warranty. IMO waist of money.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • packetjones
    packetjones Posts: 1,059
    edited March 2010
    For $100 it is not bad. I would say if you are not good with fixing electronics then get it. I did not have the warranty on my dlp and have had to replace the lamp as well as the color wheel. It is basically like opening a computer and fixing something. If this intimidates you then get the warranty. If not you should be able to fix anything that goes wrong with it.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • woodhead 2
    edited March 2010
    I know I wouldn't have a problem changing out the lamps, looks pretty simple. Maybe I will just take my chances, and say hell with it. Thanks for your responses.:p
    Panny 8000 project
    Oppo 103D
    Backs- Monitor 40's
    Center-CS 350
    Sub- SVS PB 2000
    Onkyo 607[back up]
  • potee
    potee Posts: 610
    edited March 2010
    I had a mitsy DLP bought the warrenty as it was new technology at the time it paid for power unit. Also check the SVS forum for your set it'll give you a good idea for what to do. Good luck
    Paul
