gettin rid of my rti setup , want new ht setup so recommend here
polkfarmboy
polkfarmboy Posts: 5,703
edited June 2010 in Speakers
I feel sick about this but I think its time to get rid of my ht setup and get somthing new
Is there anything else non polk thats good for ht ?
My budget for 7 speakers is about $7000 and its all gota be brand new
Post edited by polkfarmboy on
«13
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited March 2010
    Which rti's did you have?
    For HT I love klipsch and feel they are a step up from the RTI's.
    I like the RF-83's (mains) RC-64(center) RS-62( surrounds)
    About $3500
  • polkfarmboy
    edited March 2010
    Still have them ..... csi5 rti8 rti6 fxi3
    I love them but now I want more
  • polkfarmboy
    edited March 2010
    I kinda like the look of av123's open baffle speakers and that huge xvoice centre but there seems to be alot of issues with them
  • lectronicjunkie
    lectronicjunkie Posts: 299
    edited March 2010
    The guy that I bought my AVR from had it hooked up to a set of B&W's that sounded really good but I don't know what model they were. I liked them a little better than my RTi's.
    It's all in the detail.
    :cool:
    HT Setup:
    Samsung PN50D550
    Onkyo TX-SR805
    Samsung BD-D6700
    Fronts: RTi10's
    Center: CSi5
    Side surrounds: RC65i's
    Rear surrounds: FXiA4's
    Sub: Velodyne CT120
    Outdoor: Atrium 45's
    Pictures here
  • Huck344
    Huck344 Posts: 453
    edited March 2010
    PSB Imagine Series - I love the sound of them.
    Two towers, center channel and 4 bookshelfs for about $4800 new.
    As a recommendation, stay away from av123. Their president is under indictment for charity fraud and I have read some stuff on other boards about customers getting ripped off from them.
  • polkfarmboy
    edited March 2010
    Thanks huck..... Ive never even heard of psb and will go do some reading on them now
  • Huck344
    Huck344 Posts: 453
    edited March 2010
    I had never heard of them until several months ago. Local shop was playing the Synchrony 1's which sounded awesome, but are much more expensive. They were more than willing to set up the Imagine towers which I thought sounded great. IMO, the Imagines have a much warmer sound than the RTi's.
  • cstmar01
    cstmar01 Posts: 4,424
    edited March 2010
    for 7k you could also do Def Tech Mythos ST's or STS I believe.
  • john22614
    john22614 Posts: 214
    edited March 2010
    I recently replaced my LSI front sound stage with B&W804s mains and HTM4 center resulting in a nice improvement. Vocals are more natural and the sound stage is seamless, silky smooth and clear and sounds like its floating in air. The 800s series is now out of production and being replaced by the much more expensive 800 diamond series, so if you can find them at a retailer, you should be able to get at least a 20% discount in MSRP. Give them a listen if you can, and you may find them to be a strong contender.
    B&W 804s mains
    B&W HTM4 center
    Polk PSW 1000 sub
    Outlaw 990 Pre Amp
    Anthem MCA 30 Amp
    Monitor Radius 180 surrounds
    Audiosource Stereo Amp for surrounds
    Denon 2910 Universal DVD/SACD Player
    Comcast DVR
    Pioneer Elite 42" Plasma 940 HD
    Harmony Universal Remote
    Blue Jeans interconnects and biwires
    Itunes Air Express
  • Menasor
    Menasor Posts: 283
    edited March 2010
    Oh man $7k for 7 speakers? You can do a ton with that. Definitely go out and listen for yourself.
    You can put together a B&W 800 Nautilus series setup, a Paradigm Signature setup, PSB Synchrony... etc
    Basically top end stuff. Good luck!
    ps. - also at this price point, don't hesitate to go used. Definitely going go get some top notch stuff for the money
    Fronts: Energy RC-70
    Center: Energy RC-LCR
    Surrounds: Energy Veritas 1.0CM
    Subwoofer: SVS PC12-NSD
    Receiver: Onkyo TX-SR705
    Amplifier: Denon POA-2200 w/ Ben's ICs
    Pics of my setup (click me)
  • 98Badger
    98Badger Posts: 317
    edited March 2010
    Paradigm Studios and an SVS sub should be around your budget unless you're paying MSRP. The Signature line will blow them away, but you'll pay for the quality. As mentioned by huck, the PSB's are worth auditioning. I haven't had as much quality time with B&W, but I'd avoid the 600 series. They didn't impress me at all when I listened. The 800 series is another story but might be over your budget.
  • Menasor
    Menasor Posts: 283
    edited March 2010
    98Badger wrote: »
    I would go used at this price point. Most likely the previous owners would have really taken care of the speakers (due to their sizable investment) and you would probably only pay 50-60% of MSRP.
    Too bad the OP doesn't want used (just caught that). If so, you're looking at Paradigm Studio, PSB Imagine, B&W CM...
    Worth noting that Paradigm probably has the best center speaker design in this price point (they're massive)
  • ViperZ
    ViperZ Posts: 2,046
    edited March 2010
    Definitely Paradigm Studios would be in your budget.
    (not sure if B&W CM would fit that price range, cause matching HTM center is expensive).
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • polkfarmboy
    edited March 2010
    Wow so many brands unheard of and so much research to do. thanks guys I appreciate the input and unfortunately I cant go for used ones
  • mantis
    mantis Posts: 17,374
    edited March 2010
    What do you plan on driving you new speakers with? What is your room layout? What are your needs and why do you want to upgrade? What is it about the Polk Rt series you feel you need or want more? What do you do with your system mostly? How loud do you play it?
    A good step up well a big step up from Rt series speakers would be the Definitive Mythos series. Much clearer more dynamic and refined. They have a similar type sound like Polk but much cleaner and controlled. It's a good place to look into speakers. You will spend that 7k you got easy.
    Dan
  • polkfarmboy
    edited March 2010
    My room is about 17 by 22 with 9ft ceilings . I plan on adding a 5 channel $600 rotel 1075 for the avr but idealy I will get somthing like an integra and anthem amp combo laters
    I only use the audio for the occasional movie as I'm not to fussy about the 2 ch stuff yet so ht is my priority for now
    my RTI setup is amazing and I am happy with the bass but I want more detail in the midrange for those little hidden background noises
  • Montoya
    Montoya Posts: 506
    edited March 2010
    Fronts usher cp-6311, usher x-718 surrounds and rears, and X-616 center.
    Svs sub
  • BIZILL
    BIZILL Posts: 5,432
    edited March 2010
    hurry up. you can almost sell them. i call first dibs if you're in AZ. too bad you don't have a set of fxi-5's instead. i'd be all up in ya.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • MANSKITO
    MANSKITO Posts: 295
    edited March 2010
    Dude for HT definitive tech end of story lol your not going to do better then that for HT no way no how.
    http://www.definitivetech.com/Products/products.aspx?path=Home%20Theater%20Speaker%20Systems|Floor-Standing%20Systems&productid=Mythos%20ST%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20&hometheater=1
    That would blow your pants off and melt your face. And there fantastic for music too. An SVS sub and maybe 2 more surround speakers and you would have IMAX worthy sound in your house. And that would be in your budget easy.
    If you can demo the definitive tech super towers please do,
    http://hometheaterreview.com/definitive-technology-mythos-st-super-towers-reviewed/
    http://blog.stereophile.com/ces2008/011208deftech/
    I find there 2 channel performance to pretty much match or best any speaker from any brand under 5k(Polks LSI included) and there HT performance is unmatched by any speaker that I haver heard.
    Monitor 60s, CS10 front
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    Pioneer PD-5010 CD player
    Sennheiser HD 650s :D
    Maverick Audio Tube Magic D1 DAC
    AMD Phenom II 940 @ 3.8 prime stabel
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
    Creative X-fI Titanium Fatal1ty
  • Menasor
    Menasor Posts: 283
    edited March 2010
    MANSKITO wrote: »
    Haha not gonna beat them for ht no way no how? Those are some strong words :) I'd wager the Paradigm Studios would best these in both ht AND music. No way those skinny Mythos would compare to the Paradigms in dynamics and output
    The center alone is as big as two Mythos towers put together:
    http://paradigm.com/en/reference/centers-studio-studiocc690-model-3-13-1-50.paradigm
    Don't get me wrong, I'm sure the Mythos are nice speakers, but they definitely look to be more lifestyle speakers than true high performance. They would be on par with the Paradigm Millenia series...
  • Menasor
    Menasor Posts: 283
    edited March 2010
    2x Paradigm Studio 100
    1x Paradigm CC-690
    2x Paradigm Studio 20
    2x Paradigm Studio ADP-590
    Done!
  • MANSKITO
    MANSKITO Posts: 295
    edited March 2010
    Menasor wrote: »
    I have heard both the studios and the mythos and the Mythos are ANY THING BUT life style speakers. The studio/sing line from paradigms might be better for music maybe just a little but clearly you have not heard the out-put from the def-tech stuff. Yes it equals the studios and surpasses them by a large margin in HT. The super towers are one of the best speakers you can buy for HT. When it comes to bass out-putt please remember that the Super towers have POWERED SUBS and have enough bass to putt out a candle from a good distance away and they can do that and still sound fantastic just because they have a some what smaller volume (they are not by any means a small speaker, they are bigger then my monitor 60s by a good bit.) dose not mean they lack out-putt.
    You don't have to take my word for it, ask any one who has heard the Mythos super towers. They have some serious power great speakers for HT.
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
  • Menasor
    Menasor Posts: 283
    edited March 2010
    MANSKITO wrote: »
    I have heard both the studios and the mythos and the Mythos are ANY THING BUT life style speakers. The studio/sing line from paradigms might be better for music maybe just a little but clearly you have not heard the out-put from the def-tech stuff. Yes it equals the studios and surpasses them by a large margin in HT. The super towers are one of the best speakers you can buy for HT. When it comes to bass out-putt please remember that the Super towers have POWERED SUBS and have enough bass to putt out a candle from a good distance away and they can do that and still sound fantastic just because they have a some what smaller volume (they are not by any means a small speaker) dose not mean they lack out-putt.
    I'm not saying that they're not good speakers. I'm saying they are not the absolute best as you said they were. By the way, output does equal volume. If you're admitting that these Mythos towers have "some what smaller volume", then what does it do to make it better than the Paradigms? Is it clearer than the Paradigms? Do they throw a larger sound stage? Do they have better bass (this is a definite no. physics says otherwise)?
    HT performance is about large soundstage, power handling, dynamics, and output.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited March 2010
    I'd stay away from AV123...their owner is currently being brought up on charges for ripping off several charities.
    Now probably wouldn't be the best time to order anything from them...you may never get it. Just a word of warning.
    $7000 for HT speakers? I'd go with the Definitive Technologies Mythos ST's up front...with matching surrounds and center. I've heard that setup in play before...and it's nothing short of amazing.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    tonyb Posts: 33,072
    edited March 2010
    Check on a used Legacy system. Focus 20/20 used up front,3 g's, center another 750,surrounds maybe another grand, and one of their subs,and you'll have some bragging rights. Lots of choices in your price range.
  • MANSKITO
    MANSKITO Posts: 295
    edited March 2010
    Menasor wrote: »
    Ok if volume was directly proportional to out-put then what of your sub woofers of the world? How could sub-woofers that generally are much smaller then the tower speakers they stand next to put out so much more bass SPL? I understand that in general larger cabinet volume and diver surface area equals more out-put. How ever if you are comparing a speaker with a POWERED SUB to a normal speaker then it takes substantially more driver surface area/through distance, cabinet volume and power handing to equal the same out-put/SPL levels of a powered sub. And the Def-techs have powered subs.
    You don't have to tell me what makes a good HT speaker.
    Listen I have heard with my OWN EARS the Paradigms and the Def-tech myths super towers. The def-tech HAVE MORE SPL. If you think I'm mistaken please give them a listen before you say anything about there performance or the laws of physics.
    I didn't mean the Def-fech stuff was the best in the world just in his budget range there the best you can get or at the very least the best i have heard. But of course there are better speakers, you can ALWAYS spend more money but paradigm dose not make a better speaker at least as far as HT gos maybe for music I didn't really spend enough time with either speaker to pick which is my favorite for music. But IMO if it was my money and I wanted some HT speakers the Def-tech would be the speakers i would buy.
    As to sound stage its been so long i can't really compare the two from memory they both where rather good.
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
  • polkfarmboy
    edited March 2010
    def tech is on the cards but I love the size of that paradigm Studio CC-690 coming in at 70lbs
    My heads going to spin with all the researching but thats a big part of fun
  • polkfarmboy
    edited March 2010
    10k is outa my budget
    Would psb be better than the def tech for ht?
    edited March 2010
    Some good suggestions above....Mythos are 'good' for HT...I've heard them--they can do the job. Paradigms are also good....different sound. I think you need to listen for yourself. There are LOTS of others..lots....Klipsch Reference series, if you like horns, are a good choice...very efficient can throw sound all over the place.
    B&Ws only the higher more expensive models (used market--a GREAT IDEA THERE!). PSB....go USED!
    Atlantic Tech...makes a nice home theater package complete withs some GIANT subwoofers!
    And--well...there are a lot more! Also don't forget that a pair of RTI-A9s will blow away your current fronts!
    cnh
  • polkfarmboy
    edited March 2010
    This may sound dumb but I prefer to do my listening to movies at low volume without a sub so my ideal speakers would have to achive good transparency with this preference
