monitor 40 tweeter
anyone know where i can get a tweeter for my monitor 40? on one of my speakers it got pushed in and it is driving me crazy-er. i have tried all means i know of to get it out and it just won't budge.
Post edited by m1aman on
http://www.polkaudio.com/contactus/index.php
You can probably buy one from Polk customer service, but if it sounds fine, I wouldn't waste the money. It's probably like $40. -
If you're feeling frisky, use a vacuum. I'm a musician and recording engineer and have fixed speaker dents in some studio monitors I've had by just barely using a vacuum on the dents to pull them out. You gotta be quick about it, though. And of course, use a hose...not the entire vacuum.
Worst case, you end up having to buy a new tweeter, anyway.Myriad Rocker (Brandon)
Receiver - Yamaha RX-V665
Mains - Polk Audio Monitor 60's
Center - Polk Audio CS2
Surrounds - Polk Audio RC55i's
Rears - Polk Audio RC60i's
Sub - Polk Audio PSW111
TV - 73" Mitsubishi DLP 1080P HD
Other - PS3, Panasonic Blu Ray, Wii, hundreds of movies
True wisdom consists in knowing that you know nothing. Bogus...
For Sale: Polk Monitor 30's (black) still in box...
For Sale: Pinpoint AM-40's still in box... -
Thanks but I tried a vacuum already and it did remove about 25 percent of the problem.
I took Zeros advice and contacted Polk but they have not responded yet.
One trick I heard about is doing what some people do to remove small dents in metal. Warm it up with a hair dryer and then spray it with one of those compressed air in a can like Wal Mart sells. You have to hold it upside down so it will freeze. But before I do that I want to find a source for replacement. -
When you say you contacted them, did you E-mail them or call them? Calling them is always the best option as I'm sure there is quite a backlog on E-mails. They will get you hooked up.
-Jeff
1-800-377-POLK (7655)
9AM-5:30PM EST Mon-FriHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Yeah, you should definitely find a source for replacement first.
Another idea to try is to take something sticky that won't leave a residue and touch it to the dome on the tweeter and pull the dent out that way. May just work. No harm, no foul.Myriad Rocker (Brandon)
Polk does want $40 for a replacement. Hmmmmmmmmmm........... I may look for a set of used 40s on ebay and then I will have plenty of replacement parts.
i dont know what type of flange the tweeter is mounted on,but i just fixed the tweets in a pair of R10's 3/4" domes,i just open my mouth around them and sucked(sounds funny ,but its true)if you can get a good seal around the flange your in business.
LOL, that's one heck of a first post jim, lol welcome to Club Polk.
-JeffHT Rig
Blu-Ray- 80 GB PS3
