Monitor 5B's given a refurb & upgrade w/pics
geoff727
geoff727 Posts: 546
edited February 2012 in Vintage Speakers
Hi everyone. Here is a pair of Monitor 5's I just finished working on for a good friend I work with. He wanted something inexpensive that sounded and performed fairly well. I said, "I think I might have the ticket for you". So we found these that night on ebay. Here's what they looked like when they arrived (all the drivers were in, BTW).
Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS-II (modded)
Infinity RS-IIIa (modded)
Infinity RS 2.5 x 2
Magnepan 1.6QR (modded)
System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373
Post edited by geoff727 on
«13
  • geoff727
    geoff727 Posts: 546
    edited March 2010
    And here's something that always bothered me a little bit, the "mistolerances".
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • geoff727
    geoff727 Posts: 546
    edited March 2010
    Here's a few pictures in process. I filled in all of the gaps between the black melamine front panel and the veneered edge bevels, so it's much more of 'finished' look now. Crossovers, binding posts....all the standard stuff.
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • geoff727
    geoff727 Posts: 546
    edited March 2010
    Here's what they look like now. The veneer is maple. The drivers have new mounting hardware, all stainless w/ T-nuts.
    F1.JPG 433.9K
    F2.JPG 455.4K
    nh1.JPG 460.2K
    F3.JPG 358.4K
    Tops.JPG 400.7K
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • geoff727
    geoff727 Posts: 546
    edited March 2010
    Reclothed grilles, redone grille badges, binding post cups with new hardware, a lustery finish, and veneered/finished back edges.
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited March 2010
    Nice job!!!!
    Was the veneer process hard?
  • geoff727
    geoff727 Posts: 546
    edited March 2010
    And a few more, plus the basic cables I assembled for my friend for his new music system.
    Hope you all enjoy! :)
    Geoff
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • geoff727
    geoff727 Posts: 546
    edited March 2010
    Two more...
    You'll probably notice that many of the holes on The PCB are re-drilled to move things around enough to enable a nice, strong, stable, mounting to the new components.
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • WastelandWand'r
    WastelandWand'r Posts: 466
    edited March 2010
    Geoff,
    Beautiful work. Looks like a brand new set, and I know that you took your time and did it right.
    Are those t-nuts very difficult/pain in the **** to set in the MDF?
    Nathan
    Home Rig
    SDA 2.3TL's front and center
    Polk 1000p Center
    Pioneer Elite SC35 Receiver (Pre/Surround
    Sunfire Cinema Grand 5X200-Back in the mix.
    OPPO BDP-93
    Squeezebox
    Stepped up to name brand Speaker Cables and interconnects!
    Monitor 4, 5, 7, 10's, SDA 1B's, 2B's, 2.3TL's, RTA 15TL's all in storage waiting for me.
    Sales Rating #1!!
  • geoff727
    geoff727 Posts: 546
    edited March 2010
    Leroy....yes, they're a little time consuming. 20 separate pieces of veneer on each cabinet (front, bevel, side, back edge, inside back edge x 4 on each cabinet).
    Nathan...great to hear from you! I've been wondering if you still had the 2B's & 2.3tl's. After I sold all my Polk's off last year, several months later I really started missing them (even though my current system is technically superior in all areas). So, I recently sprang for some RTA 15tl's and just yesterday for some beautiful Monitor 10 Series 2's. The workshop will be busy, that's all I can say. And, I plan to pick up KC's (kcoc321) 7C's as well. I'm hopeless.
    A T-nut can be a little tricky to line up perfectly in the particle board (it's not MDF, which is much finer). Usually I have to insert a long screw into it and tap it into place while keeping the screw straight up and down.
    Take care,
    Geoff
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • danger boy
    danger boy Posts: 15,722
    edited March 2010
    Geoff, those mon 5's look great.. your work is nothing less than top notch. your friend will be so happy with those. collector items if you ask me.
    PolkFest 2012, who's going>?
  • geoff727
    geoff727 Posts: 546
    edited March 2010
    FWIW, I actually had a "punch-list" of 28 separate items for these. Including, repairing a separating seam on one of the bottom corners. I had to remove a bottom bevel, and part of one of the side bevels to get in there, clean thngs out, and re-set the joint.
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • geoff727
    geoff727 Posts: 546
    edited March 2010
    danger boy wrote: »
    Thanks Al! I still need lots of practice w/ veneer, though. I'm thinking about doing the Mon 10's in ebony or cocobolo.
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • WastelandWand'r
    edited March 2010
    Geoff,
    Thanks for the heads up. Yep, still have them, they are in the same shape as when you and I wrapped them up. Sitting in my nephews house, waiting.
    Glad to hear that you have been unable to completely escape the lure that is vintage Polk.
    I have wanted to put my ears on a set of 15's, let me know what you think.
    Nathan
    Home Rig
    Polk 1000p Center
    OPPO BDP-93
    Squeezebox
    Sales Rating #1!!
  • geoff727
    geoff727 Posts: 546
    edited March 2010
    Geoff,
    Nathan
    I'm glad you still have them. I don't miss the 2.3tl's, but I sometims think about the -2B's. I think they have real potential. If I were to ever get another SDA, that would probably be it.
    These 15's have bad tweeters, and a few cabinet dings. That's the kind of buy I like to make....just enough problems that the seller is willing to let them go cheap! It'll be a long time before I get to them. I have two other Infinity's (same ones you saw tucked away in the corner) that are mid-project and I really need to take the next year and get those things done.
    Now if i can just hold on at my job, I'll be doing fine! :rolleyes:
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • geoff727
    geoff727 Posts: 546
    edited March 2010
    This is the difference in the look with the production gaps finished off. It's just one of those nice touches, I think.
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • kcoc321
    kcoc321 Posts: 1,788
    edited March 2010
    Those look great Geoff, but then I would have expected nothing less, given the previous projects I have seen.
  • jimbo1421
    jimbo1421 Posts: 772
    edited March 2010
    Very nice veneer job, Geoff. How did you remove the vinyl?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    Parasound P3 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
  • geoff727
    geoff727 Posts: 546
    edited March 2010
    jimbo1421 wrote: »
    Jim
    Very simple. A heat gun and some type of scraper.
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
    Toolfan66 Posts: 18,189
    edited March 2010
    Geoff,
    Those look fantastic!!! Very nice work. Looks like you took your time and did all things right.
    Beautiful bro just Beautiful...
    Larry.
  • w_coyote
    w_coyote Posts: 66
    edited March 2010
    Hi Geoff, Nice job. I was wondering what you filled the gaps with and how hard was this to do. I'm going to do some 1B's and noticed they have the same gaps that you had and have been trying to figure out how and what to fill them with. Thanks in advance for your help
  • domflane
    domflane Posts: 653
    edited March 2010
    Nice work Geoff, those look fantastic. I wish my Monitor 5's looked like that.
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • Conradicles
    Conradicles Posts: 6,377
    edited March 2010
    Beautiful and thanks for the pictures. Maybe this will inspire some to do the veneer on their vintage Polks.
    Again, great job!
  • geoff727
    geoff727 Posts: 546
    edited March 2010
    Thanks for the compliments, everyone!
    w_coyote wrote: »
    It's not difficult, you just have to go slow and use care that you don't accidentally do any damage to the black melamine. For a lot of the gaps, you can run a thin strip of veneer into the gap. Once the glue is dry on it, you just level it off with the front bevel face and veneer over the top. Some gaps are really big (wider than the thickness of veneer), so you can run the veneer strip into it with a liberal amount of glue, and use LOTS of tiny wedges to kep that strip planted firmly against the melamined surface. For these thick gaps, you have to do this to prevent the wood glue from sucking that small veneer strip back away from the melamined surface as the glue dries and shrinks in size. Other gaps are really thin and are best filled with wood putty, carefully sanded, given a hair of black paint, and veneered over.
    Basically, whatever creative method you can come up with is what works! :)
    Probably a thousand different ways would work fine.
    Geoff
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • skrol
    skrol Posts: 3,464
    edited March 2010
    Geoff
    They look fantastic. How do they sound?
    I see that you lined the entire interior with Sonicbarrier, or something like it. How was the original Daycron batting placed? Did it fill the entire cabinet?
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • geoff727
    geoff727 Posts: 546
    edited March 2010
    skrol wrote: »
    Yes, the lining is Sonic Barrier. After about 2 hours of listening last night, I actually decided to remove half of the original polyfill. I had first reassembled them with the original polyfill rolls. But, having to pack it in there fairly tightly, I felt that it started to dig into the bass response a bit; I had the impression of passing the point of increasing the 'apparent enclosure volume' to definitely decreasing it. That's not based on any measurements, just a subjective impression. Anyway, the remaining half of the polyfill, I just lightly bundled and spread out within the enclosure. I'm a bit more satisfied with the bass end now.
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • geoff727
    geoff727 Posts: 546
    edited March 2010
    The 5B's getting the run-through and new components broken in. Sure is nice to listen to music through these again. Everything else is pushed off to the side for the time being.
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • Des Moines
    Des Moines Posts: 115
    edited March 2010
    Amazing work, Geoff!! It is great to see vintage Polks transformed into 21st century collector speakers. Thanks for posting your pics!
    HT in Progress
    Receiver - Harmon Kardon AVR520 5.1
    Fronts - Polk SDA 1C
    Center - Polk CS350
    Monitor - Sharp Aquos LCD
    NMT - Mede8er500x
    Cables - Signal Ultra
  • geoff727
    geoff727 Posts: 546
    edited March 2010
    Forgot these two pictures of the tops, one with a flash and one with normal light.
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • kcoc321
    edited March 2010
    Hey, like your new rack and are those new subs too :D
  • halo71
    halo71 Posts: 4,638
    edited March 2010
    Geoff, phenominal work there!
    --Gary--
