Pioneer VS Onkyo
sageleo
sageleo Posts: 170
edited March 2010 in Electronics
I'm currently looking for a new avr for my HT set up. I think I have narrowed down my selection. I'm debating between the Pioneer Elite vsx23-txh and and an Onkyo 805. Mainly will be used for games and movies. Any and all help is appreciated.
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
Post edited by sageleo on
  • bopicasso
    bopicasso Posts: 878
    edited March 2010
    Coming from someone who has owned a onkyo 805 and a pio 21txh, I prefer all the features and mcacc on the pio to the onk's features. Plus the sound of the onkyo is more bright while the pio is more neutral. With you RTI's I would definitely go with the more neutral receiver since they are already on the bright side. I didnt use the amp section in either amp so I cant comment on the difference there.
    Basically I was unhappy with the onk 805 and wanted something different. Now with the pio 21txh Im completely satisfied. Fills all my needs. Plus MCACC seems to be alot more detailed with its speaker setup compared to the Audyssey. Audyssey never setup my subwoofer properly while the MCACC blends it perfectly.
    Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
  • dvran
    dvran Posts: 280
    edited March 2010
    Onkyo 805
    ~Dan
    Projector: Epson 705HD on 106" DaLite
    TV: Samsung 50" Plasma PN50B550
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    Sub: Velodyne Minivee 10
    PS3 and Xbox
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2010
    bopicasso wrote: »
    Agree, I like Pioneer Elite avr over an Onkyo. MCACC wins.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    billbillw Posts: 7,497
    edited March 2010
    If you are planning on using the receiver alone (no external amps), the Onkyo 805 is a much more robust, powerful receiver and I don't think it is bright at all (once setup properly with correct implementation of Audyssey). Consider this: the Onkyo weighs 20lbs more than the Pioneer. Everyone who knows anything about amps knows that power requires heavy transformers, big cooling fins, big caps, etc. That is where your extra 20lbs is.
    I also think there are a lot of people who are not using Audyssey correctly. 1st of all, you have to use ALL of the available test locations (8 total) when doing room setup and you have to be careful of avoiding locations that will pick up reflections (ie: too close to tables, corners, etc). The locations should be close to where you listen and set close to ear height; you must use a tripod; the room has to be extremely quiet; and Audyssey pretty much always requires you to go back and change the subwoofer crossover point (and the xover for each speaker) and adjust the sub level with a sound meter. Audyssey admits that this is required for proper setup. Audyssey lets the OEM decide how to handle bass management (x-over points) and this doesn't always match with what the end user wants or require.
    I've heard similar setups with Pioneer Elite and I think my Onkyo 805 wins, hands down.
    Of course, I'm biased, but you can't argue about the extra power that the Onkyo has.
  • bopicasso
    edited March 2010
    I guess im just not a fan of onkyo due to my experiences, and it was because I owned a 605 and 805 and they both didnt satisfy my audio needs. Also my dad has a 806 that is a huge step down from the 805.
    Pioneer imo makes better quality products, that produce more realistic sound. Onkyo alters the sound to much for my taste. If your looking to cook something, the onkyo makes for a great heat source also! I did a side by side test from a rotel pre and the onkyo 805 and it was night and day the onkyo was ALOT more harsh or bright as they say.
    Audyssey is very easy to use and I have set up many many onkyos with it. Dont get me wrong it works, but not to the extent that the MCACC does.
    The only advantage the 805 has is a more powerful amp which really shouldnt be a reason to pick a reciever because if your looking for good quality watts you should buy a external amp. I would still choose the pio just for sound quality alone.
    My friend works at bestbuy in the magnolia dept and says the most returned problematic receivers are onkyo hands down. He says there junk! He hasnt seen one pio returned since he started working there.
    edited March 2010
    Well, your BestBuy friend aside, there are thousands of happy SR805 users over at AVSforum. I've not had a single problem in over 2 years and I push mine pretty hard at times. Perhaps their newer models are not as well built, I don't know. I'm strictly speaking of the SR805. As far as amp power, I think that is something the original poster is concerned about seeing that he is trying to sell off his separate 5-channel amp and preamp.
  • bopicasso
    edited March 2010
    I had no problems with my 805 either, had it for 1 year.
  • jrgoswick
    jrgoswick Posts: 159
    edited March 2010
    Outside input is a GREAT way to make a choice in this type of matter. I prefer the Onk-as someone else said though-EXTERNAL POWER! Really what it comes down to is what you like and can afford.
    Onkyo TX-SR705 AVR
    Onkyo M-501-Given to my father.
    Onkyo DX-C730 CD Changer
    Onkyo DV-BD507 Blu Ray player
    Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
    Polk Monitor 12's with RDO's and XO's
    Polk CS300 Center
    Polk Monitor Series 4 rears
    EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek:
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited March 2010
    I think he wants it to be a standalone receiver. if someone just wants to use it as a preamp then why get a receiver at all...just get a pre/pro.
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited March 2010
    These days most the surround pre-amps are buggy as hell, don't have the features of the latest recievers, and cost twice as much, I think a reciever as pre is really the only way to go right now.
  • bopicasso
    edited March 2010
    Completely agree WilliamM2
    Afordable used preamplifiers are out dated.
  • mantis
    mantis Posts: 17,329
    edited March 2010
    I have setup and used both products many times and prefer the Pioneer Elite receivers over the Onkyo models for sound quality. There is nothing wrong with either unit and I'm sure they would make you happy. The Elite models from the vsx21txh to the mighty SC-09tx all share a sonic signature thats warm and comfortable yet powerful and dynamic. Without going separates Pioneer in my opinion makes the finest sounding receiver lines.
    Personally I went from owning Rotel separates to a SC-07 which says a lot about Pioneer Elite.
    Dan
  • emoxley
    emoxley Posts: 205
    edited March 2010
    I also say the Onkyo. I love my 805! If you don't close it in, or sit something on top of it, heat shouldn't be a problem. Mine is on the bottom shelf of my tv stand, and barely gets warm, after almost 18 hrs. of use, a day. And I'm driving three 4 ohm speakers, without an external amp. My other four speakers are all 8 ohm.
    Samsung HL61A750 LED DLP
    Onkyo TX-SR805 receiver
    Oppo BDP-83 blu ray player
    Polk Audio LSi9 front speakers
    Polk Audio LSiC center speaker
    Sony SS-MB100H rear speakers
    SVS PC12-NSD powered subwoofer
    Pioneer PL-514 turntable
    Logitech Harmony 628 Universal Remote
    edited March 2010
    Well, it sounds like a divided camp, which really only means that they are both great products.
  • tbui2007
    tbui2007 Posts: 128
    edited March 2010
    i love my onkyo 805
    LSI15 Front LSIC Center Lsi7 Rears Lsi7 Sides DSW600
    Sony S560 Blu-Ray DVD
    Sony 46W5100
    Monster HTS-3600
    Sunfire TGP-401 Pre
    Sunfire Grand 200x7
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited March 2010
    I agree with mantis that dollar for dollar the pioneer receivers are as good as it gets. From the bottom all the way up to 2K I think they're very hard to beat
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited March 2010
    I am an Onkyo man myself and love my 806, but the Pioneers get a lot of good press from some very well respected members here. I have not heard the new Pio's so I can't offer any advice on those, but the Onkyo's are very good units as well. I have owned two myself and have been very pleased with both. Good luck.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
    edited March 2010
    I've heard the Elite 21 and it is a nice receiver...but it's not in the Onkyo 805 league. I agree with billbillw above the 805 does NOT sound 'bright'. The Burr Brown Dacs and the extra power actually give it quite an authoritative sound. It sounds wonderful with M70s...Rtis are generally brighter---period.
    The Wolfson DACs in the 21 are also nice.
    The lower Pioneer models, IMO cannot hold their own against the lower Onkyos like the 60x and 70x series. More features....more power, better surround sound.
    Now if we're going to start talking about ICE Pioneer Elite amps...I would have to rethink my discussion above. But no ICE amp can be had for the price of an 805?
    Therefore, the VALUE pick is the 805 hands down!
    cnh
  • AGUERRA
    AGUERRA Posts: 147
    edited March 2010
    i've only had onkyo so i cant compare the two but what i can say is the 805 is a beast as most say and has been reviewed by many and has a strong following. if u can try to listen to the two and let your ears decide for you
    front: rti8
    center: csi5
    surround: fxi3
    sub: eD a2-300
    receiver: onkyo 805
    ps3
  • tboo72
    tboo72 Posts: 225
    edited March 2010
  • ryanjoachim
    ryanjoachim Posts: 2,046
    edited March 2010
    If it matters any, i've been "happy" with my onk 605 for the past 2 years, and am looking to upgrade to the 805. The feature set and expandability sold me.
    MrNightly wrote: »
    "Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
    mystik610 wrote: »
    Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
    My System:
    TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
    HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
  • concealer404
    concealer404 Posts: 7,440
    edited March 2010
    I haven't had my ears on the higher end Oinker receivers. I've had the 50x, 60x, and 70x models.
    My last two Pioneers had no problems blowing them away in almost every department. (VSX D850s and VSX-50 Elite)
    They sounded warmer, had an air of "effortless power" about them.
    Now... the 805 from all accounts seems to be an entirely different ball game. So i don't really know which is the "right" answer. Me personally? I'm more loyal to Pioneer at this point, and like the "house sound" better than that of Onkyo, so that's probably where i woudl go.
  • Montoya
    Montoya Posts: 506
    edited March 2010
    The pioneer is a great unit I use to be an onkyo fan but my last two have been pioneer. Elite 82, and now elite 94 I still have found no reason to upgrade and probably won't for many years.
    edited March 2010
    I'll grant you that the new Elites are great AVRs, I've heard the older mid-tier Elites and I really don't see what the fuss is about, sorry?
    I stand by my early remarks. I've owned non-Elite Pioneers and I prefer my Onkyos in that price range. The exception this year might be the Pio 9040 since it's more or less a VSX-21 Elite clone!
    Onkyos have always had more power than an equivalent priced (non-ELITE) Pioneer model! I had a Pioneer 700 and an 800 series that weren't clean at all!! The 1000 series was usually, like the 9040 a clone of the entry level Elite and usually a GOOD BUY!
    But I do like the ICE Elites fine. These are the BEST AVRs Pioneer has made in years. It's put them back in the GAME! A game they were falling behind in for a while!
    cnh
  • sageleo
    sageleo Posts: 170
    edited March 2010
    I think I'm going to be going with the Pioneer. Most likely the VSX23txh, unless I manage to sell my current set up before I make my purchase. I have decided to go with Pioneer because I keep hearing that Onkyo seems to be on the bright side. If I do sell my current set up then I will be upgrading to the SC-25.
    Thanks for all the input,
    Dirk
    edited March 2010
    The SC-25 is an 'excellent choice' you'll enjoy it! And that coming from an Onkyo man? Those Elites are wonderful receivers and newer tech than the 805 (I have one of those--which I actually like quite a bit but it's getting 'old'--tech wise!).
    cnh
  • disneyjoe7
    edited March 2010
    I had a high end Onkyo 898 one time, I replaced it with a Pioneer 84 Elite AVR. Between those two avr I love the Pioneer Elite 84 vs the Onkyo 898. I think I'm talking about 1500.00 AVR's so not sure about mid <$1000.00 AVR vs Pioneer and Onkyo but I think Onkyo would win over that.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • jimsvm
    jimsvm Posts: 307
    edited March 2010
    My 9040 is pron to over heating when pushed.Love the sound,Go ICE power,or a seperate with a 9040 or equivilant.IMO
    i
    Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
  • Slinger182
    Slinger182 Posts: 512
    edited March 2010
    jimsvm wrote: »
    i
    Does it get so hot that it turns off? My onkyo runs really hot but in never stopped working or anything bad happened. I finally got a fan pretty much just for piece of mind. It seems it is quite common with the oinkers to run hot.
    I've been interested in the 9040 because it has pre outs and it plays nice with my iphone. But where did it come from? It seems to have come out of no where and it's not on Pio's main page just in the for sale area.
    Panny 55-st30 plasma
    Pioneer vsx-1121
    Parasound 2100 pre
    b&k tx4430 amp
    Oppo bdp-83
    Monster HTS 3500
    polk TSi500s Vr3 Fortress modded
    polk CS20 center channel Vr3 Castle modded
    polk Owm 3 surrounds
    polk PSW505
  • digitalvideo
    digitalvideo Posts: 983
    edited March 2010
    I never understood why people settle for the VSX line of Pio recievers? Why not just buy a Pioneer Elite SC-05 that you can get off ebay or audiogon or videogon for a good price? It's worth the $300 more.
