Okay, ONKYO Electronics Owners...Sign in and Show Us Your Gear!
123457
  • Mike LoManaco
    Mike LoManaco Posts: 974
    edited August 2009
    Interesting; yeah, I will probably get the OPPO as well, based on the review Home Theater gave it, although it seems this deck is going to be pretty difficult and challenging to set up/calibrate.
  • kuntasensei
    kuntasensei Posts: 3,263
    edited August 2009
    Not from everything I've read. Its setup wizard looks easy as hell. No matter though... I'm a tweaker at heart, so the more options, the better!
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • Mike LoManaco
    edited August 2009
    Weird; I read and heard the opposite. :confused:
  • kuntasensei
    edited August 2009
    Yes, there are a ton of options in the setup menu, but initial setup is very quick and easy for most people. Check out this video: http://www.youtube.com/watch?v=QrEwkBwtP1k
    Equipment list:
    Emotiva XPA-3 amp
  • Mike LoManaco
    edited August 2009
    Thank you -- I see the Setup Wizard you're talking about, and I am watching it now, yet it still seems a bit daunting to me; for example: Does the "Auto" HDMI resolution, as on my Panasonic now, control DVD AND Blu-ray output? The picture controls...does that middle "Normal" position indicate no sharpness, etc. is being used? This doesn't seem nearly as simple as my 'BD10A...
  • Mike LoManaco
    edited August 2009
    Also -- in the AUDIO SETUP section, you can only set HDMI audio streams to BITSTREAM or PCM, but it doesn't seem to separate DOLBY TRUEHD, DTS MASTER AUDIO, etc...ALL HDMI audio codecs are lumped in with one another; that seems weird to me...
  • kuntasensei
    edited August 2009
    That initial setup is just the basics. There should be individual settings for all of that stuff in the actual setup menus, but the basic setup wizard looks like it gets you up and running very fast outside of some tweaking here and there.
    Equipment list:
    Emotiva XPA-3 amp
  • Mike LoManaco
    edited August 2009
    Oh, so there is a way to go beyond the wizard and get deep into the settings? That's refreshing, because it didn't seem like many of those parameters made much sense -- such as lumping ALL surround codecs together and putting them under "HDMI" to then select "BITSTREAM" or "PCM;
    I mean, what if you want, say, Dolby Digital bitstreamed, but TrueHD PCM'ed yet both are coming over HDMI? It didn't seem possible under that video you supplied...
  • kuntasensei
    edited November 2009
    Not to revive an old thread, but I just pulled the trigger on the Onkyo TX-NR1007 while Newegg had 'em for $999.99. Ought to be a nice step up from my TX-SR705 (which a friend bought as soon as I mentioned it), and I plan on getting some speakers to use as height channels within the next week or so. I'll snap some pics and post my impressions once I get it all set up.
    Equipment list:
    Emotiva XPA-3 amp
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    My Oinker M-5150, and my old TX-SR503 that has since left us.
    The M5150 is being put through the ringer by Nik right now, attempting to drive some bigass SDAs. :) Seems to be doing decently. I need to research if it's bridgeable. We both decided it was a pretty good sounding amp yesterday.
    I like your case might I ask where did you get it?
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • concealer404
    concealer404 Posts: 7,440
    The rack you mean? It's a Planet3 unit, i got it from Fry's, you should be able to order it at a bunch of places. I'm not sure what the going rate is for it anymore, but i do know that the matching TV stand ran about $280. :p
  • Mike LoManaco
    Concealer's rack reminds me a bit of my Bell'O "audio tower" which is L-shaped and also has unconcealed shelves and backs; although I have done the best with cable management, my next rack will not be open like this. I cannot stand even seeing a little of my cables, no matter how well they're tied or channeled...
  • anamorphic96
    anamorphic96 Posts: 31
    edited March 2010
    I'm not an official Polk owner but figured I should contribute since I have been posting in this neck of the woods.
    My mighty Onkyo TX-SR506.
    I have since removed the bricks from under my center channel as they did not seem to make a big improvement. I will be getting MoPads in the near future and angle it up a little. The TV will be on a stand just over the center.
    I recently added room treatments to deal with a slap echo problem. Which is now solved and things sound much better.
    I could not forget Henry as he is one my partners while watching movies.
    The rest of the gear consists of -
    Paradigm - Mini Monitors v.1 - L/R
    Paradigm - LCR350 - Center
    Energy - C1 - Surround Speakers
    Marantz DV-4001 - Upconverting DVD Player
    Velodyne SMS-1 - Subwoofer EQ
    HSU Research STF-2 - Subwoofer
    Nintendo Wii - Game Console
    Vizio 37" LCD TV - 1080P
    So thats my system.
  • Mike LoManaco
    edited March 2010
    So thats my system.
    I thought you were running something more powerful than that Onk -- this is your main AVR?
  • anamorphic96
    edited March 2010
    Yes. But it does just fine and gets plenty loud for me. I have my eye on the 608 or 707 as my later upgrade this year.
    It was room treatments or new receiver with my tax return. So I decided on room treatments as they would provide the biggest improvement in sound with the money I had.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited March 2010
    Damn!...the 608 is out already? It seems like the 607 just came out.
    Looks like we're already getting AVR's out with support for the latest pointless technologies.:rolleyes: Interesting that the 6 series has THX Select2 Plus certification now. They've also finally got 1080p upscaling in it. Looks like the 6 series has finally been improved a bit. Still no preouts though...which makes it entry level in my book.
    It's using the Burr Brown DAC's...so it sounds like Onkyo's been listening to all of the people who prefer the 805's still. It's also got HDMI 1.4 now...with 3D compatibility.
    I'd skip the Onkyo 6 series if you're looking to upgrade. It won't really be much of an upgrade over your 506. I'd step up to at least the 7 series...if not the 8 series. Keep in mind that the 6 series doesn't have preouts, so no external amplification.
    Amplification wise, the 6 series would give you next to no advantage over the 5 series.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • anamorphic96
    edited March 2010
    I'd skip the Onkyo 6 series if you're looking to upgrade. It won't really be much of an upgrade over your 505. I'd step up to at least the 7 series...if not the 8 series. Keep in mind that the 6 series doesn't have preouts, so no external amplification.
    I tend to agree with you and will probably go with the 707 when the prices start dropping. I don't really need much power especially with an 80hz crossover point. Thats why I was considering the 608. The 506 gets louder than I need it to and never struggles to keep up.
    The HD audio, video processing and upgraded Audyssey will be nice to have though. I also like the THX processing modes. Especially the RE-EQ function. It does a better job than Onkyo's Cinema Filter function.
  • comfortablycurt
    edited March 2010
    Yeah, those are the big drawbacks to the 5 series. They lack a lot of the processing capabilities of the higher level models.
    What speakers are those that you're using?
    How do you like the Velo SMS-1? I'm planning on eventually integrating some stereo subs into my 2 channel rig...and have tossed around adding a sub EQ eventually.
    Also, keep in mind that more power provides more benefits than being louder. It's also able to reproduce sound at lower volumes with much more authority, and is able to handle large dynamic swings much more efficiently. For instance...during a passage with quiet dialogue, you might be using a total of 2 watts from your amp...and then a huge explosion hits, and taps into your amps full reserve. A higher powered amp will have more power on tap, and will be able to reproduce the dynamics of that explosion with a lot more headroom, and less distortion.
  • anamorphic96
    edited March 2010
    I guess you didn't read my gear list. ;):D Paradigm Mini Monitor v.1 with matching Paradigm LCR-350.
    The SMS-1 is one of the best purchases I have made. Boy did it tighten up the bass. I'm within 3db all the way down to 25hz with a slow roll off to 20hz. Then it drops off sharply. I really understand why people love HSU subs. Clean tight linear bass.
    The video function is the main reason I chose the SMS-1. Seeing everything in real time makes adjustments really easy.
  • Mike LoManaco
    edited March 2010
    Yeah, if you go onto Onk USA's site, you'll see a plethora of new models that aren't even out yet, for 3D support, HDMI 1.4 and such -- the site even lists them as "Coming Soon."
    The 608 is on that Coming Soon roster...
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2010
    What do you guys use to clean your gear? I'm always doing a full cleaning of our place on a weekly basis, almost, and when it comes to getting at the equipment in the rack, I just brush the 605 and my other gear over with a paper towel that has a bit of Endust on it, giving the aluminum faceplate(s) a bit of a shine -- how do you guys clean your gear?...
    Mike, don't use paper towels, they will scratch plastic display faces. Use a chamois with warm water, wrung well. I've used this method for years and my equipment always looks as new. A chamois can be used on everything safely---HDTV screens, speaker cones, case work, wood, metal, plastic.
    Sorry for the de-rail...
  • Mike LoManaco
    edited March 2010
    steveinaz wrote: »
    Thanks, Steve!
    No de rail at all, my friend! Thanks for the tip!
    Yes, I have since begun using this method (funny you mentioned it in this thread) of warm water on a lint free cloth to clean the dust, even on the aluminum faceplates of the gear. :)
    Is there anything you specifically use on your HDTV screen, outside of this aforementioned method? My rear pro's screen is pretty loaded with smeary fingerprints and such, but it's made from a coated anti-glare material that doesn't seem to clean at all with those "screen cleaner" fluids...
    Do you recommend the warm water method for the screen, as well?
  • anamorphic96
    edited March 2010
    I don't have an issue with finger prints as I don't touch my equipment and only use remotes. However I dust things with a swiffer and use compressed air to get dust of the buttons and knobs. Works perfectly and leaves no residue.
  • steveinaz
    edited March 2010
    I use the same chamois well wrung on my dlp screen. I would recommend buying a "dedicated" chamois (LOL) as car brake dust can destroy display faces and other easily scratched surfaces. It also works well on speaker grills, as there is no lint. I don't use ANY cleaning products on my equipment.
  • steveinaz
    edited March 2010
    Be careful with compressed air as well, typically it has moisture in it that can corrode potentiometers, switches, etc. Ever notice how canned air creates frost---then the frost melts and you are left with....you guessed it, water.
    billbillw Posts: 7,494
    edited March 2010
    I do something similar to Steve, but I use a large microfiber polishing cloth instead of a chamois. I use it on all my electronics, including my RPTV screen, my plasma screen, my LCD computer monitor. Sometimes, I even use a bit of mild dish soap if my goal is to remove some extra greasy toddler finger prints. Just don't ever let any liquid run down the screen. If you do and it gets to the bottom, the back side of the lenticular screen will act like a siphon and pull the liquid up into the crevasses leaving dark stains. The stains eventually dry out and clear up, but you are pretty much stuck with them until they dry. Like anything, just use caution and don't over do it. To much pressure can remove surface coatings even with the most delicate cloth.
  • kuntasensei
    edited March 2010
    Now that you mention it... it just occurred to me that my 1007 is curiously absent of Onkyo's Cinema Filter function. Maybe they've ditched that altogether in favor of RE-EQ (which is still there).
    Equipment list:
    Emotiva XPA-3 amp
  • anamorphic96
    edited March 2010
    Any Onkyo with THX processing loses Cinema Filter. As the re-eq is more accurate to whats used in commercial cinemas. Granted the roll off is not as extreme as in a cinema. I really wish it was adjustable like the Pioneer system.
  • kuntasensei
    edited March 2010
    I don't use it anyway. The Audyssey rolloff is better. But then, considering it's a refinement of Tomlinson Holman's original work with THX, I guess it would be.
    But... what rolloff in a cinema? The whole point of it in home gear is to compensate for near-field listening because movies are mixed to the theatrical standard. There is no rolloff in the theater. It isn't necessary in a theatrical space.
    Equipment list:
    Emotiva XPA-3 amp
  • anamorphic96
    edited March 2010
    Actually all commercial cinemas roll of the high end starting at 2k with a 3db roll off per octave.
    This link will explain things really well.
    http://www.hometheaterhifi.com/volume_9_2/feature-article-curves-6-2002.html
