Weird issue with my new tv
ryanjoachim
ryanjoachim Posts: 2,046
edited March 2010 in Electronics
So, with my old Mitsu DLP, when I hooked it up to my computer to watch movies it worked great. Full-screen was actually full.
With my current tv, it seems to have issues with the "full" part in full screen. It uses most of the screen, but there's a 1 inch black bar on all 4 sides of the tv that the picture doesn't fill in. This is in addition to the letterbox on most movies.
Has anyone had this issue before?
MrNightly wrote: »
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
mystik610 wrote: »
Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
My System:
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
Post edited by ryanjoachim on
  • gdb
    gdb Posts: 6,012
    edited March 2010
    My new Panasonic has a few format choices, full,just,hi fill & zoom. Using the zoom setting usually fills the screen area, getting rid of the black bars and doesn't crop out too much of the picture. Have you read your manual all the way through? Might be a fix in there somewhere.:)
    edited March 2010
    If you use the zoom function,you loose a bit of detail. Do you have an auto function that automatically adjust the screen size to the content played?
  • gdb
    gdb Posts: 6,012
    edited March 2010
    Mine does not:( I'm just using the zoom for a while to avoid the black bars during the first 300 hrs of break in on the plasma display. I don't really see much detail loss in the zoom mode anyway.;)
  • cheddar
    cheddar Posts: 2,390
    edited March 2010
    Computers are great for seeing what your TV does because you control the resolution and it's easy to see if parts of your screen are being cut off when your icons get clipped. However, sometimes graphics cards have options and settings that may have to be adjusted too. When I got my new computer monitor, I noticed a border around my screen. Not only that, but the text seemed fuzzy and I knew there was a scaler at work somewhere. I had to dig into my graphics card settings. It had defaulted to some sort of 80% setting where it was shrinking the 1080p picture. Make sure your graphics card is sending out the proper signal first. If it is, then a pixel by pixel mode on the TV should show a full screen.
  • scottfox
    scottfox Posts: 37
    edited March 2010
    U didn't say what the new TV is. On my Pioneer Kuro, there are several chices, as with most newer TVs. Yours is probably set for raw display with no overscan. See if yours has a setting that gives somewhere in the neighborhood of 4 - 10% overscan. That should stretch the picture to fill the screen without the zooming & stretching distortions.
  • JimKellyfan
    JimKellyfan Posts: 696
    edited March 2010
    I have an old 32 " tube Sony,( still 1080P or 1080U capable can't remember ), but I too have an issue, depending upon my source. I just live with it.
    Too, you are in the same boat, depends on your source.
    My receiver upscales everything to 1080P, and the computer display, like cheddar says, you can control your scaling, depends on your video card and any aftermarket scaling programs. I like www.majorgeeks.com website for goodies on the puter, as well as cnet.
    How do you like the Mitsu ?
    I was thinking of one of those, but heard you have to buy a 100 dollar bulb every year or two.
    Also to help more, like Scottfox says, which specific model ?
    Onkyo TX-NR636
    Main - polkaudio Monitor 60's
    Center - polkaudio CSI A6
    Sub - polkaudio PSW10
    Sub2 - polkaudio PSW505
    Surrounds - polkaudio Monitor 40 series II
    Front Height - polkaudio Monitor 40's
    Audio Outdoors
    Pioneer VSX 406 - polkaudio Atrium 5
    Shed
    Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
    Shed 2
    Nakamichi soundbar
  • ryanjoachim
    edited March 2010
    The TV model is in my sig: TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
    I haven't been able to find any options in the ATI Catalyst program to help. (I have a Radeon 4650). All the files i'm trying to play are true 720p or 1080p.
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
