A Cache of Tubes!
Hillbilly61
Hillbilly61 Posts: 702
edited March 2010 in Electronics
Hi All,
I decided to stop into a local 2nd hand store (this particular store is more like "junk store") to see if I could get lucky and find something audiophile for, like, $5. Just before leaving, a half dozen boxes of tubes were noticed in a neglected corner. It looks like they had been there for a very long time.
Several hundred of tubes there! Most, if not all, appear to be American brands (RCA, Sylvania, etc) and I would guess 1950s and 1960s vintage. They appear to be brand new (in boxes, no darkening of the glass, etc) and tend to be larger sized ones.
It would be a shame to see the tubes of interest for music use go to waste there ... and perhaps eventually thrown out to make space. I know very little about tubes but will offer to dig though this cache to pull out the gems for anyone that is interested.
Here's what I need to get started:
* Make;
* Tube number;
* Any other info you deem pertinent (like I said, I don't know much about tubes).
This is an opportunity to stock up in a yard sale situation. Both on sought after tubes, as well, as "lesser grade" but good to have around tubes too.
Let me know if you are interested. The cost would be what it costs me to buy and shipping. Most tubes there are under $10.
Post edited by Hillbilly61 on
  • george daniel
    george daniel Posts: 12,096
    edited March 2010
    well let's not be picky
    6DJ8/
    12AU7 12AX7 6CG7/6FQ7
    you know what,, if the price is right,,just buy em all,,you'll monst likely re-coup you investment right here on this forum,,and then some.Good Luck
  • schwarcw
    schwarcw Posts: 7,358
    edited March 2010
    What a very nice offer! I would be interested in these any make:
    12AX7 or 7025
    12AU7
    EL84
    7189
    7591
    Thanks for your very nice offer.
    Carl
  • daboyz
    daboyz Posts: 5,207
    edited March 2010
    12AT7's and 5YG3T's if there are any.
    Thanks so much,that's mighty cool of ya!!
  • lightman1
    lightman1 Posts: 10,796
    edited March 2010
    Jackpot!
    EL84's please.
    heiney9 Posts: 25,409
    edited March 2010
    6v6
    5691
    6sl7
    12at7
    5v4
    5z4
  • Hillbilly61
    edited March 2010
    OK guys,
    Like I said, I don't know how many of the desirable tubes are there, so here is a prioritized list of who gets what. This is based on in the order of who spoke up for which particular tube.
    Tube 1st Dibs 2nd Dibs 3rd Dibs
    5691 heiney9
    7025 Schwarcw
    7189 Schwarcw
    7591 Schwarcw
    12AT7 daboyz anonymouse heiney9
    12AU7 George Daniel Schwarcw
    12AX7 George Daniel Schwarcw
    5v4 heiney9
    5YG3T daboyz
    5z4 heiney9
    6CG7 George Daniel
    6DJ8 George Daniel
    6FQ7 George Daniel
    6ls7 heiney9
    6v6 heiney9
    EL84 Schwarcw Lightman1
    Keep 'em coming! I wont be back there until next weekend. This list will be updated Friday night.
    Lee
  • JimKellyfan
    JimKellyfan Posts: 696
    edited March 2010
    12AX7
    mine is for my Crate TD35
    Onkyo TX-NR636
    Main - polkaudio Monitor 60's
    Center - polkaudio CSI A6
    Sub - polkaudio PSW10
    Sub2 - polkaudio PSW505
    Surrounds - polkaudio Monitor 40 series II
    Front Height - polkaudio Monitor 40's
    Audio Outdoors
    Pioneer VSX 406 - polkaudio Atrium 5
    Shed
    Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
    Shed 2
    Nakamichi soundbar
  • Hillbilly61
    edited March 2010
    JimKellyfan - added to the list.
    To briefly update, an activity my son & I were attending fell through and we decided to take a preliminary look see in the referenced local "junk store" since we were driving past. One box of boxed tubes and one box of loose tubes were perused before it closed.
    George Daniel and daboyz are "in the money" with a 6CG7 and a 12AT7 tubes found! Total cost per: $1. These came out of the xerox box containing loose tubes. They appear used as evidenced by darkening of the glass and some very slightly bent pins.
    While perusing, I found some very close number matches to the tube numbers so far listed:
    12AT6;
    12AV6;
    6CG8;
    6cG8A.
    Any interest?
  • schwarcw
    edited March 2010
    Thanks for being so generous!:D
    I didn't see anyone ask about 6SN7. If you find any of these I would be interested.
    Best regards,
    Carl
  • Hillbilly61
    edited March 2010
    schwarcw wrote: »
    Best regards,
    You are first dibs on any of that series found!
  • Dawgfish
    Dawgfish Posts: 2,554
    edited March 2010
    Thanks for the offer! That is very kind of you. I am intersted in the following types of tubes:
    6922/6DJ8/ECC88/7308 All of these are interchangeable.
    6AK5/6AK5W/5654/CV4010 All of these are also interchangeable.
    Thanks again.
    Steve
  • Hillbilly61
    edited March 2010
    Dawgfish wrote: »
    Thanks again.
    Steve
    You have first dibs on these, except 6DJ8. George Daniel mentioned this number first ... so you are 2nd.
  • Dawgfish
    edited March 2010
    Thanks! I sure do appreciate it.
    Steve
  • chargerman426
    chargerman426 Posts: 419
    edited March 2010
    If you don't mind I'm trying to get ahold of EL34, 6CA7, or KT77. They are a larger tube and should look like this.
    http://www.tubedepot.com/eh-el34.html
    If life had more tubes it would be a lot smoother.
  • headrott
    headrott Posts: 5,496
    edited March 2010
    If available I would like 6V6s, after H9 that is, and any 6DJ8/ECC88/E88CC/6922/7308 and most imoprtantly Siemens E188CCs and Siemens CCa. Also, any KT88 and 6550 tubes. Thank you for offering to buy them and then offer them to us.
    Greg
  • Hillbilly61
    edited March 2010
    Chargerman426, headrott:
    Duly noted.
    To comment to all, if there are cross over tube numbers, then list them as you post. The order of priority of who gets first and subsequent dibs on the specific tube is determined by the order who lists the specific number.
    It is observed that some savvy posters have already done this, so it is felt fair to remind all. Of course, some of you single tube number posters may prefer that particular number and I am cool with that too! :cool: :D
    Also,
    Chargerman426, any relation to Lightman1? :p
  • chargerman426
    edited March 2010
    Nope no relation :)
    so if I follow you rules then I want
    EL34. 6CA7, and KT77
    6CA7, KT77, and EL34
    KT77, EL34, and 6CA7
    So am I fist in line for all three kinds :)
  • Hillbilly61
    edited March 2010
    Nope no relation :)
    Yes -mostly. I quick checked my list, but will not bother to double check if you are first or 2nd to 100% of what you earlier posted for full verification. What you posted earlier (separating the number by a slash "/") was quite sufficient.
    I am on top of what tube numbers who posts first and the "/" is recognized as a distinction. The final list will be posted Friday night.
  • chargerman426
    edited March 2010
    Hillbilly what's the status of the tube hunt?
  • Hillbilly61
    edited March 2010
    Doing the "big dig" tomorrow. My daughter needed to be taken back to college today from spring break, as she announced yesterday she needed to get some things done around her apartment before classes kick back in on Monday. (I suspect new boyfriend sort of thing ...).
    With last night being her last night home a while, we gave the HT a workout as it was declared "movie night". HT is such a great family activity! The Polks acquitted themselves very well in a movie marathon sitting!
    Here's the list of tube numbers posted thus far and who has dibs (by order of who called for which specific number first):
    5691 heiney9
    7025 Schwarcw
    7189 Schwarcw
    7591 Schwarcw
    12AX7 George Daniel Schwarcw JimKellyFan
    5654 Dawgfish
    5V4 heiney9
    5YG3T daboyz
    5Z4 heiney9
    6550 headrott
    6922 Dawgfish headrott
    6AK5 Dawgfish
    6AK5W Dawgfish
    6CA7 chargerman426
    6CG7 George Daniel
    6DJ8 George Daniel Dawgfish headrott
    6FQ7 George Daniel
    6LS7 heiney9
    6SN7 Schwarcw
    6V6 heiney9 headrott
    7308 Dawgfish headrott
    CCA headrott
    CV4010 Dawgfish
    E188CC headrott
    E88CC headrott
    ECC88 Dawgfish headrott
    EL34 chargerman426
    KT77 chargerman426
    KT88 headrott
    EL34 chargerman426
    Any last minute changes or additions are welcome, but if they come in after I go look then cest la vive!
    As stated last Sunday, George Daniel and daboyz have spoken for tubes found with a 6CG7 and a 12AT7 sitting on my desk during a very incomplete preliminary look see. Cost $1 per tube plus S&H.
    Lee
  • Hillbilly61
    edited March 2010
    Here's the results from the scavenger hunt at the junk store today.
    daboyz: 1 - 12AT7. While unboxed, closer inspection suggests that it is unused. My cost $1.
    Dogfish: 3 - 6AK5. 2 RCAs NIB. 1 GE unboxed, appears to be unused. My cost $5.
    George Daniel: 2-6CG7. 1 unused GE in a Sylvania box and 1 definitely used, brand unknown (remaining ink suggests RCA), unboxed. My cost: $3.
    PM me re shipping particulars and any advice as to how to pack for shipment. Since the number of finds in this cache were so few, I declare this a Karma! If we hook up some time in the future, you can buy me a beer. ;)
  • Hillbilly61
    edited March 2010
    PM me re shipping particulars and any advice as to how to pack for shipment. Since the number of finds in this cache was so few, I declare this a Karma! If we hook up some time in the future, you can buy me a beer. ;)
  • chargerman426
    edited March 2010
    Lee,
    Even though I didn't end up with any tubes I do want to thank you for extending the offer to fish though tube to find some that we were looking for.
  • Hillbilly61
    edited March 2010
    Lee,
    Thanks for the kind words. At CP, it is offered that we are a club provided at the good will of Polk Audio. Hence, we help everyone out.
    Flamers can be taken care of by the diligence of the moderators. I do not care of the flamers' post count. Flamers embarrass our most gracious host with their actions within this forum.
    Lee
