Laptop upgrade help.
shack
I need to upgrade the ram in my wife's laptop. Right now she has twin 512MB DDR2 SDRAM, 667 MHz DIMMs. I'm looking to upgrade to a minimum of a single 2G 800 MHZ DIMM or possibly go ahead with 2 for 4G of ram. Next step will be to get rid of Vista for Windows 7.
Dell wants $66 each...not a bad but would like to do better. Anyone know where to pick up some quality DIMMs at reasonable prices?
"Just because youre offended doesnt mean youre right." - Ricky Gervais
Post edited by shack on
Memory Fast in your neck of the wood (Kingsport TN):
http://www.memorysuppliers.com/?Test_30_content=Google_2672443823&gclid=CPnEqImftqACFQ8bawodlV0FTg
I've been ordering memory stuff from them since 2001 (I think). Fast and reliable, along with great price.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
Interesting...no cheaper than Dell."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Check out Crucial and Kingston brands.
Frys.com (sometimes has good deals after rebate) and Newegg.com (I think you will get charged sales tax in TN).
If you upgrade to Windows 7 (32 bit), you will only be able to see 3 GB, I believe. 2 x 1 GB, IMO, is probably plenty for Windows 7 unless you do video editing or heavy photoshop type stuff. Windows 7 (64 bit edition, which is actually also supposed to be more secure than the 32 bit edition), can see all 4 gb of ram.
I would say about $40 is fair price for 2 x 1 GB PC800 DDR2 SO-DIMM right now.
You could also check out eBay if you find a reputable seller you are comfortable with. -
i've had good luck with sticking to DELL.
and if the price is close then go for it.... -
Definately go to crucial.com have had excellent luck with these guys!!Testing
Testing
Testing -
mshan242700 wrote: »
Sorry, not a good idea, the reason I go with crucial is they always have the right memory for a particular store brand computer, it will do a scan on your computer too if you want...Testing
Testing
Testing -
Thanks for the info guys."Just because youre offended doesnt mean youre right." - Ricky Gervais
Win7 32 bit will see all 4 GB of ram but can only use just over 3 (3.14 if I remember right) I'm in the more ram the better camp. I'd put 3 GB in, if not 4. It doesn't cost all that much more, but that's just me."The secret of happiness is freedom. The secret of freedom is courage." Thucydides
