A new amp....for me at least..Rawson F-5
NotaSuv
NotaSuv Posts: 3,871
edited March 2010 in 2 Channel Audio
A very nice sounding Rawson built F-5 this one makes me rethink the whole more is better thing ;) took quite a while to warm up but damn it sounded great..
Here's what Nelson himself has to say about the F5 :
"So far, First Watt has made a few different amplifiers: Very different amplifiers.
Quite a few people have asked me for a regular sort of amplifier, you know the kind you plug like any other, with some voltage gain and a real damping factor. Amplifiers that have low distortion and noise, and will drive a 4 ohm load.
The last time people asked for that they got the Aleph J, which satisfied most of those requirements. Single-ended Class A, the Aleph J is an easy-going design which is happy driving 8 ohm loads with a warm, relaxed presentation.
By way of contrast, I present the F5 (taa-daa!), a push-pull Class A amplifier, utilizing JFETs and MOSFETs in a very simple two stage complementary circuit – a little bit like a complementary version of the Aleph J. But like all the other First Watt amps so far – this one is different.
In many ways, it’s an ordinary topology - the basic circuit is found in numerous preamp circuits and the odd power amplifier (Check out the Profet amp from Selectronics). But the F5 is the product of numerous decisions that set it apart.
It has very wide bandwidth, DC to > 500 KHz.
No capacitors anywhere in the circuit. (except in the power supply, of course!)
It has a high input impedance – 100 Kohms, and a high damping factor (~60)
The distortion is very low, between .001% and .005% at 1 watt.
It’s very quiet, about 60 microvolts or so.
It will drive a 2 ohm load without burping, and 1 ohm without misbehaving.
Did I mention that it sounds terrific?"
25 watts per channel of Class A goodness.
__________________
Post edited by NotaSuv on
    heiney9 Posts: 25,430
    edited March 2010
    Now you're getting a taste of what my Aleph sounds like. Simple is better --2 gain stages, single ended class A. Tim Rawson is well known cloner, but I can imagine a real F5 would even be better.
    Glad you are enjoying it.
  • NotaSuv
    edited March 2010
    heiney9 wrote: »
    sounds very nice and warms the room at the same time....thanks
  • Face
    Face Posts: 14,340
    edited March 2010
    I just sold one of these.
    Nice sounding amp, works best with a medium/high gain pre and efficient speakers.
  • NotaSuv
    edited March 2010
    Face wrote: »
    Thanks looking for a pre now................
  • daboyz
    daboyz Posts: 5,207
    edited March 2010
    Face wrote: »
    I was gonna say............
