33 Minute XP Installation Hangup
  • exalted512
    exalted512 Posts: 10,735
    edited February 2010
    Also, it is the disc that came with the netbook
  • nguyendot
    nguyendot Posts: 3,594
    mini 10?
    service tag por favor
    Main Surround -
  • exalted512
    Service tag gnxkhj1 express service code 36275622589. Its a mini9.
  • nguyendot
    ill look.
    i'm guessing the diagnostics passed?
    Main Surround -
  • exalted512
    Diagnostics?
  • nguyendot
    Should be an option when you hit 0 on boot.
    Main Surround -
  • exalted512
    Never tried it
  • nadams
    nadams Posts: 5,877
    To run the diagnostics, there should be an option when you press F12 for the boot menu during the POST.
    Ludicrous gibs!
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • fatchowmein
    fatchowmein Posts: 2,637
    exalted512 wrote: »
    I'm using the disc I got with it from Dell via a usb powered disc drive.
    What I'm about to propose is a very, very remote possibility so use this information as you see fit.
    I have seen a Windows install freeze like that on a laptop using an external cdrom drive powered by USB only. If it's available, try using another external dvd/cd drive that is powered by an ac adapter.
    http://support.microsoft.com/kb/828267
    Good luck
  • Systems
    Systems Posts: 14,873
    Does it have a recovery partition on it?
    Testing
    Testing
    Testing
  • nadams
    nadams Posts: 5,877
    edited March 2010
    Any luck with your installation problem?
    Ludicrous gibs!
  • nguyendot
    edited March 2010
    Have you tried to install from a usb thumbdrive instead? I hear that works well. In fact Dell has Ubuntu and XP on thumbdrives to ship to people without optical disc drives. You have to request it from technical support. I'm not sure if the XP thumbdrive is still in stock or not, I couldn't find it in the system.
    Main Surround -
  • phipiper10
    phipiper10 Posts: 961
    edited March 2010
    I had this same problem and did some research.
    You need to restore your pc hardware and bios settings back to factory defaults.
    This means disconnectiong any extra hard drives you might have installed and also deactivating same in bios.
    This means reducing RAM back to original amounts and setting that in the Bios. On many you can't reinstall when ram is over 3gb. After reinstall you can go back and add back in your HD and ram again with no issue.
    After I disconnected my HD and reduced the RAM I was by the 33 minute hangup.
    This was my experience and YMMV.
    GL
    Rich
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • nguyendot
    edited March 2010
    His netbook can't even support over 2gb, so the 3gb limit on windows install isn't an issue (there's also a switch on install you can use to bypass this anyways).
    As far as changing stuff back to stock, there isn't much you can change on a mini9 that will cause his issue.
    Main Surround -
  • exalted512
    edited March 2010
    I havent even messed with it. If I have time, I'll try some more tomorrow. It has been sitting like this for a couple months because I havent had time to play with it.
    -Cody
  • nguyendot
    edited March 2010
    You can send it to me and I'll fix it ;)
    I'm DCSE certified among other things (not that it matters).
    Main Surround -
  • exalted512
    edited March 2010
    nguyendot wrote: »
    I talked to dell yesterday...they said to send it in as it sounds like a hardware problem.
    -Cody
  • exalted512
    edited March 2010
    Well, it doesnt say what they did...but it works now!
    -Cody
  • audiobliss
    audiobliss Posts: 12,518
    edited March 2010
    That's what you wanted! Glad it's all worked out now.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • nguyendot
    edited March 2010
    That works! Let me see what they did...
    they just replaced the hard drive with an imaged one.
    seems easy enough.
    Main Surround -
