Ugly psw505
Slinger182
I really don't like the way my sub looks with the grill off so I always keep the grill on. Here's a pic http://www.hometheaterhifi.com/volume_12_2/images/polk-psw%20505-subwoofer-driver.jpg
Thinking about painting the gray part black. If it looks like crap well then I just go back to what I'm doing now which is just keep the grill on. Can anybody recommend a type of black spray paint I should use? For example flat or gloss. Or is this just a really bad idea?
The reason for all of this is that I built a box out of 2x8s to put my center channel in and I put my TV on top of that box. I'll post pictures later of before and after. It's just bare wood so I'm going to be attempting to paint that black as well.
I have 2 days off from work starting tomorrow, first day off in over 2 weeks, so I figure I need to find something constructive to do besides drink my self dumber and laundry.
Panny 55-st30 plasma
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk TSi500s Vr3 Fortress modded
polk CS20 center channel Vr3 Castle modded
polk Owm 3 surrounds
polk PSW505
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk PSW505
Post edited by Slinger182 on
Sounds like a good project.....I don't know about the drinking part..but please do the laundry.....gots to have clean clothes ...... sounds like you need a couple days off .. Happy listening
I would use flat for sure, krylon type.Home Theater
Polk RTi8
Polk Monitor 40
Polk CSi5
Polk MicroPro 2000
Visio 42 LCD
Denon AVR 790
Samsung BD 1600
Two Channel
Polk SDA 2B -
Here's the painted sub. I used semi gloss.I think it turned out pretty good.Panny 55-st30 plasma
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk PSW505 -
Slinger182 wrote: »Here's the painted sub. I used semi gloss.I think it turned out pretty good.
As far as I can tell, if you're inclined to leave the grill off... that's an improvement!
+1... Looks much better than that greyish color Polk tend to use for their subs.mdaudioguy wrote: »As far as I can tell, if you're inclined to leave the grill off... that's an improvement!
Just be carefull of any enclosure for your center as it may dratiscally alter the sound (Boxy type of sound)DARE TO SOAR:
Looks good, I agree its an improvement.Home Theater
Polk RTi8
Polk Monitor 40
Polk CSi5
Polk MicroPro 2000
Visio 42 LCD
Denon AVR 790
Samsung BD 1600
Two Channel
Polk SDA 2B
