Would this fit my car?
Systems
k i was wonderin if the polk momo 5 1/4 component system will fit my 2000 grand prix. i know that the factory hole is 5 1/4 but i herd the magnets make it hard to install.. an also would the Kenwood KAC-729S amp be a good selection to power the momo 5 1/4's which are 100wEACH(200wPEAK) or power my infinity kappa 6x9's which are 110wEACH(330wPEAK) or is it possible to power all of them. the amps 600w not sure about the specs..
Testing
Testing
Testing
Testing
Testing
IMHO anything will fit into any car if you're willing to make it fit.Hemi: (HEM -e) adj. Mopar in type, V8, hot tempered, native to the United States, carnivorous, eats primarily Mustangs, Camaros, and Corvettes. Also enjoys smoking a good import now and then to relax.
www.crutchfield.com , just click on what fits my <A TITLE="Click for more information about car" STYLE="background-color: #f0f000; " HREF="http://search.targetwords.com/u.search?x=5977|1||||cars|AA1VDw">car</A> under car products tab.Panasonic VIERA 46" 1080p plasma
Onkyo TX-SR805
Klipsch RF-7(bi-amped)
Klipsch RF-25
Xbox 360 with HD DVD
Playstation 3
Cobalt Cable -
post the specs or a link to that amp...were too lazy to look it up...that and we're not the one with the question
-Cody -
KENWOOD KAC729S
600 WATT MAX
300WATT RMS
Stereo, Mono or Tri-Way output
300 watts x 1 in bridged mode
150 watts x 2 at 2 ohms
Requires 8-gauge power and ground leads
80 Hz selectable low-pass crossover, 18 dB/octave
Speaker-level inputs
4-way protection circuitry
Signal-to-noise ratio 100 dB
Dimensions: 9"W x 2"H x 11-7/8"DTesting
Testing
Testing -
it'll put out 100x2 at 4 ohms which is the only load you'll want to run those components at so it'll be good to push them. You definately don't want to put the components at 2 ohms though, i had my mm6's at 2 ohms for about as long as it took me to turn the car on and find out how bad it sounded, the x-overs wern't made to run a 2 ohm load...Hemi: (HEM -e) adj. Mopar in type, V8, hot tempered, native to the United States, carnivorous, eats primarily Mustangs, Camaros, and Corvettes. Also enjoys smoking a good import now and then to relax.
