Questions about RTi8
HurleyAshes25
Hello,
I am thinking about buying a pair of RTi8's to update my home theater system front speakers on the eBay store. I have a powered sub.
I was wondering will a Onkyo receiver TX-Sr307 with only 65W per channel be able to power these speakers effectively?
I am only running smaller speakers for the surrounds. and have gotten a CSi3 from another user for cheap.
Thanks.
Thanks.
Post edited by HurleyAshes25 on
It will power them, but you will definitely see an improvement with an external amp (don't know if the 307 has pre-outs). I have the SR805 (105wpc). The speakers sounded good with that unit, but sounded much better when I added my sunfire amp.
I have the RTiA5's which are the newer version of the 8's. I am using a HK254 with only 50 wpc and my speakers soundd good. I was worried about the power as well before i purchased them but it turned out fine.
Dont worry about the power and get them. Worse cse dont turn them up extremely loud and you will be fine.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
Yes, but HK 50 Watts/Channel is alot different then Onkyo's 65W/Channel am I wrong?
HurleyAshes25 wrote: »Yes, but HK 50 Watts/Channel is alot different then Onkyo's 65W/Channel am I wrong?
Agreed - I wouldn't go by an AVR's rated power unless it is an HK or NAD.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
Thats what I have heard. lol.
i am pretty sure that you would be fine. You would just want to watch the volume so that the amp doesnt clip trying to push the speakers to hard. Depending on your budget and needs i would either get the 8's and start saving for a new amp. Or get a new amp and start saving for the 8's.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
You'll be fine for now. Like Packetjones said, careful on the volume.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
You will have no problem, enjoy!Home Theater
Polk RTi8
Polk Monitor 40
Polk CSi5
Polk MicroPro 2000
Visio 42 LCD
Denon AVR 790
Samsung BD 1600
Two Channel
Polk SDA 2B -
The RTi8's are pretty efficient, and don't really take a lot of power to sound great. You'll be fine running them with your 307.
They would definitely sound better with a good external amp, but they should sound great off of just your AVR too.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I have a set of RTi10's and ran them off of my old TX-SR501 which was 65w per channel. I thought they sounded good. I upgraded to a TX-SR606 which is 90w per channel and could tell a nice improvement in sound. That's only a 35w jump. I can't imagine what they would sound like with a 200w amp. Must be like heaven.
Just don't make the mistake like I did and upgrade to something without pre-outs.It's all in the detail.
:cool:
HT Setup:
Samsung PN50D550
Onkyo TX-SR805
Samsung BD-D6700
Fronts: RTi10's
Center: CSi5
Side surrounds: RC65i's
Rear surrounds: FXiA4's
Sub: Velodyne CT120
Outdoor: Atrium 45's
Pictures here -
lectronicjunkie wrote: »I have a set of RTi10's and ran them off of my old TX-SR501 which was 65w per channel. I thought they sounded good. I upgraded to a TX-SR606 which is 90w per channel and could tell a nice improvement in sound. That's only a 35w jump. I can't imagine what they would sound like with a 200w amp. Must be like heaven.
Most definitely!
