Passive Radiator
stephen0630
stephen0630 Posts: 41
edited March 2010 in DIY, Mods & Tweaks
I have a question and or a concern about the passive radiators on my SDA 1C's. Today I installed Mortite in the place of the factory gaskets and replaced a passive radiator. After I was done swapping out the bad radiator I noticed that there was a metal bolt on the old passive radiator. The one that I had just put in didn't have one. Do I need to remove the radiator and put the bolt from the old one in it or just leave it alone?
Onkyo TX-SR703
Carver M-4.0t
Polk SDA-1C's
Polk Monitor 4
Sony SS-B1000
Infinity Entra Sub
Sony SCD-CE595
Sanyo TP 727 Turntable
Magnavox Blu-ray Player NB500MG1F
Phillips 42" LCD 1080p
Xbox 360
Wii
    Toolfan66 Posts: 18,064
    edited March 2010
    If you are talking about the silver weight on the back side, Yes I would put it on your new one..
  • stephen0630
    edited March 2010
    Yes I am referring to the weight. I wasn't sure if it would effect the sound.
    Onkyo TX-SR703
    Carver M-4.0t
    Polk SDA-1C's
    Polk Monitor 4
    Sony SS-B1000
    Infinity Entra Sub
    Sony SCD-CE595
    Xbox 360
    Wii
